Rough Running '81 4WD Toyota Truck #954043 07/16/09 06:04 PM
O
oldtoyotatruckdriver Offline OP
Stock '81 starting running rough at 2,000 to 2,500 rpm recently. Idles smooth and seems to smooth out under hard acceleration. I would say the truck "surges" more than runs rough. I cleaned carb and checked all vacuum lines. Everthing is okay. Float level on carb is okay too. Changed fuel filter, plugs and air filter - no change. Suggestions? Maybe EGR failure?
Re: Rough Running '81 4WD Toyota Truck [Re: oldtoyotatruckdriver] #954044 07/20/09 03:41 AM
kewlynx Offline
Yep, clean your EGR valve; likely carboned up. Your roughness thru that RPM is pretty tell-tale.
I don't think you can get the EGR gasket by itself anymore; you'll have to pick up an intake manifold gasket and trim it off to use when you put it back together.
Let us know how it goes; welcome to the board!
**ubi apis- ibi salus**
Re: Rough Running '81 4WD Toyota Truck [Re: oldtoyotatruckdriver] #954045 08/01/09 01:53 PM
Stevie Offline
Pretty much nothing left but the EGR valve. Let us know after cleaning it. If you don't want to buy the whole intake gasket, just buy some bulk material and trace/cut away.
Ahh..Stanwood. Used to look out my backyard over to you from Whidbey Island. Eleven wonnderful years up there. Are you keeping cool right now? Drink a cold one at SeaFair for me. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'80 4X4 Longbed
Re: Rough Running '81 4WD Toyota Truck [Re: Stevie] #954046 08/01/09 05:29 PM
stock87 Offline
And another tip, in my experience, it's usually the pipe that goes from the EGR to the manifold that gets carboned up, not the valve itself. Check the 90? bend where it goes into the manifold.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6044 MB (Peak: 0.6602 MB) Data Comp: Off Server Time: 2026-06-07 04:27:00 UTC
