Check your wheel bearings
#954098
07/17/09 02:28 AM
If you haven't checked your front wheel bearings lately, it might be a good idea. I started getting a vibration that comes and goes. I decided to jack up the front wheels today and check for bearing play. Sure enough, the drivers side was fairly loose. I put new bearings in, about six months ago. Did that side without the big socket. Used channel locks. I now have the big socket. I adjusted the drivers side back to specs. I'll probably have to replace them before long. Right now all is good. Just thought I might remind everyone to check them from time to time.
J-Bird
'95.5 T, SR5, Bone stock w/32x11.50's '06 Sonata LX
Re: Check your wheel bearings
[Re: J_Bird]
#954099
07/18/09 04:46 AM
Yes, it's important to use the proper socket, torque them to spec, and properly use the lock washer.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5846 MB (Peak: 0.6328 MB) Data Comp: Off Server Time: 2026-10-25 22:24:54 UTCValid HTML 5 and Valid CSS
