Cert issues #954456 07/19/09 08:06 AM
4x4Wire Offline OP
I have been noting a few issues with "certificates" when accessing the portal (www.4x4wire.com)
Is anyone noting strange behavior???
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Cert issues [Re: 4x4Wire] #954457 07/22/09 05:44 AM
Jeff the marmot Offline
Of the several times that I've accessed the portal the last few days, I haven't seen a problem until just now. My IE7 just complained about a security certificate. It didn't give any more info and I wasn't able to squeeze any more info out of it. I said ignore and it displayed the page normally.
Re: Cert issues [Re: Jeff the marmot] #954458 07/22/09 06:13 AM
4x4Wire Offline OP
If it occurs again, I need to know what is displayed in the browser URL window.
For example, if you access the site using www.4x4wire.com, it should bring up the portal home page.
However, I have noted that on occasion, it will display the IP address and shift to requiring an ssl certificate for an encrypted session;
However, I can enter a /index.php and the site loads normal. Except that it will append a /home to the url.
It is a puzzling display....
John Stewart
Editor - 4x4Voice
Re: Cert issues [Re: 4x4Wire] #954459 07/22/09 07:39 AM
Not in Firefox V3.0.11 <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Cert issues [Re: 4x4Wire] #954460 07/22/09 03:50 PM
Adam F Offline
Using IE8, I had a certificate issue. The main page loaded but a bunch of the graphics diddnt load. A pop up came up saying it blocked content and I chose to load anyways.
97 4R, stock, daily driver
Re: Cert issues [Re: 4x4Wire] #954461 07/27/09 11:53 AM
little_joe Offline
Former Admin
John, I finally experienced this issue. A ticket with Rackspace is in order for them to generate and install a valid certificate.
I'll look into the SEF config as well b/c that seems to be causing some issue.
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Cert issues [Re: little_joe] #954462 07/27/09 03:56 PM
4x4Wire Offline OP
I had a ticket with Rackspace for configuration check. Nothing abnormal.
They suggested correlating error with a log entry which I have been trying to do.
The only abnormal thing I find is a request for 10.5.96.6 which seems to relate in time to when I see an IP address displayed requesting an ssl session in my browser.
I opened a new ticket this morning requesting the generate a valid site cert.
John Stewart
Editor - 4x4Voice
Re: Cert issues [Re: 4x4Wire] #954463 07/27/09 07:23 PM
BTW, I haven't seen the error again since I saw it almost a week ago. I'll let you know any more info if I see it again.
Re: Cert issues [Re: Jeff the marmot] #954464 07/28/09 04:56 PM
4x4Wire Offline OP
Rackspace has installed a valid cert. For the time being, it is "self-signed". However, there was no cert prior. So, it can't hurt and it might help.
Please post if anyone encounters an invalid token or invalid cert error.
John Stewart
Editor - 4x4Voice
Re: Cert issues [Re: 4x4Wire] #954465 07/31/09 12:05 AM
Adam F Offline
Still getting invalid token with IE8
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6444 MB (Peak: 0.7655 MB) Data Comp: Off Server Time: 2026-07-09 13:28:45 UTC
