Need brake help
#954486
07/19/09 03:09 PM
I went to replace the pads and rotors on my wifes 01 sporty and broke off one of the lower caliper bolts, in attempt i totally jacked up the stand that the caliper bolts to. So I need a new one, where can I find this part at??
94 Zj custom suspension and other stuff 01 F250 tow hoe 5" exhaust 00'sporty 3" lift 235's
Re: Need brake help
[Re: minydigger]
#954487
07/20/09 04:12 AM
do you have a dealer in your area? part # 0k04533662 don't get the bolts mixed the top and bottom are different.
Re: Need brake help
[Re: bombardj1]
#954488
07/21/09 10:35 AM
Yeah thats totally not the right part# Nice Fail though. Found the part at a local yard dealer wanted 70 got it for 25 and 4 new caliper bolts from parts store for 9 so not to bad.
Re: Need brake help
[Re: minydigger]
#954489
07/21/09 01:36 PM
? what part do you have for the lower long bolt ? dealer # the upper dealer # should be 0k04533661 sleeve-pin bolt and 0k04533662 these slide the caliper. The mounting bolts are # 0k01133302. the lower long sleeve-pin bolt should be the # I gave before. but still would like to know the dealer #'s you have. Thanks
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
Re: Need brake help
[Re: bombardj1]
#954490
07/22/09 12:13 AM
bolts were never an issue the caliper stand is what I was talking about
Re: Need brake help
[Re: minydigger]
#954491
07/22/09 12:57 AM
the part you call a stand, if I have it right is the knuckle assy. ? that's what the caliper assy. bolts to. well you did say you broke off a bolt.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6096 MB (Peak: 0.6788 MB) Data Comp: Off Server Time: 2026-05-29 22:44:43 UTCValid HTML 5 and Valid CSS
