what is a DRB II FLASH PROGRAMMING KIT ? #954519 07/20/09 01:10 AM
ghostraider Offline OP
is this something that i would care about for my 1989 Raider?
Went to a Flea market Today and saw this. Guy wants $500 and included some cartridges but not for my year.
The seller says he got it from a mechanic friend's (who had died) wife. Does not know if it works or what vehicles it would apply.
All the cartridges were for like 93 to 95 ?
seemed sort of pricey ?
<img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: what is a DRB II FLASH PROGRAMMING KIT ? [Re: ghostraider] #954520 07/20/09 02:13 AM
First off, 1989 is not an OBD 2 system.
Second Mitsubishi did not support flash programming till the early 2000s in some models, later in others. That is a vague statement but I did not feel like looking up the details.
But basically non Canbus ECUs are generally non flash.
Flash programming is where we can reprogram the lookup tables such as mixture and timing in the computers.
Re: what is a DRB II FLASH PROGRAMMING KIT ? [Re: OldColt] #954521 07/20/09 03:54 AM
Brianawd Offline
You can reflash any Mitsu ecu as long as its eprom and you can read the code. People have been doing it for years on DSM/3000gt/evos.
92 Galant vr4 11.17at132mph
98 Montero 2.5"lift,33/10.50/15,15x8procomp wheels.
trail-gear rock sliders,ARB front bumper,Warn m8000 winch. Piaa lights.
Re: what is a DRB II FLASH PROGRAMMING KIT ? [Re: OldColt] #954522 07/20/09 04:27 AM
I sort of understand. There is nothing there for me to flash !
Re: what is a DRB II FLASH PROGRAMMING KIT ? [Re: ghostraider] #954523 07/20/09 04:44 AM
kewlynx Offline
Keep yer $500 for your trail carnage budget; my plugged nickel. <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
Re: what is a DRB II FLASH PROGRAMMING KIT ? [Re: Brianawd] #954524 07/20/09 11:52 AM
In those cars the ROM gets swapped out for a programmable EPROM that allows for remapping. At least that is the way I have been doing it. I do not know of anyone reprogramming the factory chip.
I also have an old prom burner that I have used for 15 years. That was the old read, wipe, flash real PIA to do. Real old tech compared to the way it is done now.
The Canbus is a system that multiplexes many signals over just two wires to run many functions. In Mitsus case the column switches have three wires running from the switches into a relay module that does the switching of say the lights and wipers.
The earliest Can system used in Mitsubishi were the outside rear mirrors in the 94 Diamantes.
Mercedes is the pioneer in CANBUS systems in vehicles. From the early 90s even the tail lights use Mini control units to switch the bulbs. In full CANBUS vehicles there are essentially no fuses anymore. The circuits are monitored to determine current draw and the computer determines to put out power or not to the device. Kind on neat but has taken awhile to learn how the alter some of the functions.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6170 MB (Peak: 0.7033 MB) Data Comp: Off Server Time: 2026-11-03 04:54:16 UTC
