drive belt question 97 rodeo #954619 07/20/09 07:57 PM
SOURCE7769 Offline OP
there are 3 drive belts on the 97 3.2 4wd rodeo i know the one closest to the engine is the alt belt the middle belt is the a/c belt , does that a/c belt do anything else or can i drive with that belt off i try to tighten it but it wont tighten plus i donmt use the a/c anyway i was wondering if id do damage by not having that belt on while driving
97 rodeo 3.2 4wd
Re: drive belt question 97 rodeo [Re: SOURCE7769] #954620 07/24/09 08:34 AM
boritz Offline
1. Yes - you could remove the A/C belt without any worries (except the A/C won't work of course).
2. How are you trying to adjust it? - the adjuster is the idler pulley - there is a 17mm lock-nut in the face of the idler bearing and then the adjustment is done with the long 10mm bolt.
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5876 MB (Peak: 0.6354 MB) Data Comp: Off Server Time: 2026-06-07 07:06:18 UTC
