Page 1 of 4 1 2 3 4
Idle Air Control #955137 07/23/09 01:26 PM
homerdog Offline OP
Anyone know where to get one for a halfway decent price. The things are $150 at Autozone. Am I going to have any problems, other than high idle, by running with the thing unplugged until I can get a new one?
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: Idle Air Control [Re: homerdog] #955138 07/23/09 02:20 PM
bombardj1 Offline
try ebay or a junkyard
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: Idle Air Control [Re: homerdog] #955139 07/28/09 12:49 AM
DennisThompson Offline
I bought on off ebay a while ago. If you go to the Bosch web sight and cross referance the number you will know what other cars use the same idle air controler. It will help with your search on ebay. Mine came off a Jag I believe.
Dennis
Re: Idle Air Control [Re: bombardj1] #955140 07/28/09 12:49 PM
homerdog Offline OP
I tried the junkyard I usually go to and they instituted a new minimum of $50 for pulling parts and also said I would have to buy the entire engine. I laughed and walked out. Gonna try a different junkyard today if it doesn't rain, either that or buy the $40 (+$10 shipping) one off of ebay.
2011 Kia Forte EX
Re: Idle Air Control [Re: homerdog] #955141 07/28/09 01:35 PM
bombardj1 Offline
why do you thing it's bad ?
Re: Idle Air Control [Re: bombardj1] #955142 07/28/09 03:17 PM
homerdog Offline OP
My Sportage will barely run when it's plugged in and runs okay when it's not. It's been unplugged for three or four days now and it seems to be losing some power, so something is probably getting crudded up somewhere.
2011 Kia Forte EX
Re: Idle Air Control [Re: homerdog] #955143 07/28/09 04:22 PM
bombardj1 Offline
change out air clearner, clean gently the MAS Flow with only mass flow clearner, clean throttle body, change fuel filter. when was the plugs changed last. anyone else here jump in.
Re: Idle Air Control [Re: bombardj1] #955144 07/28/09 04:30 PM
homerdog Offline OP
Plugs were changed late last fall and one of the coils is going bad so that's part of it. I went to change the coil, put a new one in, put everything back together and it ran like crap. Put the old coil back in and still ran like crap and started throwing a bunch of codes, one of which had to do with the IAC so I unplugged it and it started running much better. I still have to put the new coil back in it.
2011 Kia Forte EX
Re: Idle Air Control [Re: homerdog] #955145 07/28/09 06:46 PM
bombardj1 Offline
could be the harness that goes to the coils they get brittle, how old are the 2 plug wires ?
Re: Idle Air Control [Re: bombardj1] #955146 07/28/09 06:55 PM
homerdog Offline OP
The plug wires are new last year, the wires that go to the coil are suspect because the plugs are in bad shape and I have to be pretty careful taking them off and putting them back on.
I went to the junkyard at noon, they had an IAC on a Hyundai with a 6 cylinder engine but it was mounted differently so I didn't think it was the right one, got back to work and checked online and it is the right one so I get to make another trip after work to go get it. Pain in the butt to get to though because they have the highway entrance ramp blocked off by work so I have to take the long way.
2011 Kia Forte EX
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6367 MB (Peak: 0.7597 MB) Data Comp: Off Server Time: 2026-10-22 07:38:08 UTC
