high idle with recent valve cover gasket change #955577 07/26/09 01:24 AM
8
89toy96 Offline OP
3.4L just changed the valve cover gasket, cleaned the intake, cleaned the MAF. Now it is idleing at 1750. When it was cold it would start at 1500 then start climbing. Any thoughts??? I already disconnected the battery once and just let it sit. The Check engine light was on the first time, but not the second time after i disconnected the battery
Thanks
Re: high idle with recent valve cover gasket change [Re: 89toy96] #955578 07/26/09 03:37 PM
ErikB Offline
Toyota Moderator
You may have a worn throttle body. My truck did the same thing after I cleaned it out. I inspected it more closely and found the the throttle plate has slightly worn the throttle body on the side opposite the cable and springs. The little bit of gunk that was in there prevented it from leaking much, but cleaning it "solved" that problem, so now air leaks around the plate. If I wiggle/push on the throttle I can sometimes get the idle to drop back down, but its kind of hit and miss.
For this reason, I don't recommend cleaning these things. I've never seen one that was dirty enough to cause problems. Ironically, the problem starts after we clean it.
Solution is live with it, replace the TB, or have someone like LC Engineering bore it out larger, which is about $300, but its still cheaper than a new one.
http://home.4x4wire.com/erik
Re: high idle with recent valve cover gasket change [Re: 89toy96] #955579 07/26/09 08:08 PM
Adam F Offline
Double check your vacuum lines and intake hoses for cracks or leaks. Use a propane bottle or starting fluid to spray around and see if the idle jumps, also listen for hissing sounds.
97 4R, stock, daily driver
Re: high idle with recent valve cover gasket change [Re: Adam F] #955580 07/26/09 09:44 PM
BamZipPow Offline
Might be the IAC valve as well... <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: high idle with recent valve cover gasket change [Re: BamZipPow] #955581 07/28/09 02:28 AM
8
89toy96 Offline OP
well guys, looks like the problem fixed its self. The other day I drove it around after letting it sit for 24 hours and it was idleing around 1500. Then this morning it dropped to 1250. At that point I was thinking I could live with 1250 no problem. Then when I drove it home from work later today it went back down to 750. I didn't touch a thing. I wonder if there was still cleaner in the MAF? I did spray it pretty well and gave it 6 hours to dry. Thanks for the input anyways guys.
Re: high idle with recent valve cover gasket change [Re: 89toy96] #955582 07/28/09 07:46 AM
kewlynx Offline
Sounds like the feedback loop recalibrated itself. For more info on that and more, read the tech articles at www.autoshop101.com Great stuff. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6112 MB (Peak: 0.6815 MB) Data Comp: Off Server Time: 2026-06-07 04:37:23 UTC
