Page 1 of 3 1 2 3
Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good #955591 07/26/09 05:26 AM
DRaider90 Offline OP
Something to consider for those using stock 6" wide rims that do any good amount of wheeling in tight spots. With the stock BS and a narrow tire (9.5 or 10.5) you leave yourself open to a lot more body damage. I will get some pictures posted of the damage on both sides of my truck, but I have learned the hard way wider tires or rims with 3.75"-4" BS do a lot of good to help you keep your truck off of obstacles.
The thing is unless you get wheel spacers you will have to get new rims with a different backspacing (BS) to make the tires stick out a little bit further from the fenders. And at that point if you are investing in new rims you might as well get an 8" wide rim and run some wider tires anyway. You would have to buy a 7" wide rim, and then limit your future options (going wider) so you could be able to run a 9.5" wide tire (also increased risk of popping beads). You could get away with a 10.5" tire on a 8", but it would be interesting airing down to lower PSI ranges/possibly popping beads.
So really unless you just have $$$$ growing on a tree in your back yard if you run skinny tires on stock rims you run a large risk of body damage on any serious wheeling in tight spaces. Pictures of damage to fallow. <img src="/forums/images/graemlins/shiner.gif" alt="" />
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: DRaider90] #955592 07/26/09 06:46 AM
LandRaider Offline
this is very true. it took me several trashed fenders, and doors to realize this.
Personally i like the look and performance of skinnies, so IF I had to do it all over again, I'd run skinnies with fender guards tied into some rocker protection.
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: LandRaider] #955593 07/26/09 07:53 AM
SandRaider Offline
I wheeled 10.5 wide tires on 8" wide rims aired down to 11psi and never popped a bead. I'm now running 12.5 tires on 8" wide rims but I haven't aired them down yet, I probably start with 20psi and see if a bead pops
Eric
89 Raider V6, 35s, 5sp, welded rear, 8k winch
89 Raider 2.6 going on 84 4runner frame
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: SandRaider] #955594 07/26/09 01:13 PM
Mad_Scientist Offline
I like the look of the skinnies too. They have a more utilitarian look to me.
Your problem Eli is an obsession with TSL's <img src="/forums/images/graemlins/lol.gif" alt="" /> It's pretty easy to find a set of used 33/12.5 muds and a cheap set of used rims. You know that. But then I guess cheap is a relative term.
Did you get much body damage last time we wheeled?
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: Mad_Scientist] #955595 07/26/09 01:40 PM
sparkem Offline
I have run 11.5 wide tires on 8in and stock 6in rims. Never had a problem with beads. I would think the wider tire on a skinny rim would not pop the bead as easily as a skinny tire on a skinny rim.
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: sparkem] #955596 07/26/09 01:45 PM
icysyrup Offline
My 11.5's are run on my stocker 7" rim. I have gone down as low as 12psi and pinched em good and not pooped a bead. I am getting 34ltbs here in the next week and will see how they perform on the stock rim for a bit. Will be getting steelies shortly after to put them on.
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: icysyrup] #955597 07/26/09 03:55 PM
powerRam50 Offline
i run my 12.5 on my 8" rims all the time down to 8 to 10 psi and have not blown a bead yet.
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: icysyrup] #955598 07/26/09 05:12 PM
ncdieselwrench Offline
Well if you don't eat them, they probably won't come out the other end.
1993 Chevy Suburban 2500- Tow Rig
1991 Mitsubishi Montero LS LWB
SR Parts:
Rear Axle
Coils
Trailing Arms
Front Calipers
and soon to have UCA's and idler arm.
Dual Bouncies
Air Lift Airbags
Aisins
33x12.50x15 Custom Grooved TSL's
Body lift in the near future.
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: ncdieselwrench] #955599 07/26/09 06:11 PM
rolling_down_the_hill Offline
tires should be wider than rims. a 12.5 tire sits fine on a 8" wheel. bead will not fail. and having a tire stick out isnt going to prevent you from body damage. the more you wheel and the better you get helps prevent it, but if you wheel you get body damage.
88 raider 4.3 about to be parted out.
87 raider 4cy on 32's
Re: Skinny Tires + Stock BS Rims + Ruts/Highwalls = Not Good [Re: rolling_down_the_hill] #955600 07/26/09 07:30 PM
icysyrup Offline
x2. If you wheel you will get damage....its inevitable. How you wheel is your choice and that is the biggest factor IMO. You can choose to take the trench with roots sticking out of it that will damage or not...you can choose to take the extra 15 minutes or thereabouts to pull cable to get yourself safely around "body damage obstacles". my winch has saved me lots of dents, and I am not ashamed to admit that I want to use it when I might incur damage. I mean...they arent there to "look pretty" on the front of your rig are they?
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6447 MB (Peak: 0.7694 MB) Data Comp: Off Server Time: 2026-06-09 21:58:38 UTC
