Do you have the book? #955669 07/27/09 04:10 AM
BigJim Offline OP
Haynes Manual Translations
Haynes: Rotate anticlockwise.
Translation: Clamp with visegrips then beat repeatedly with hammer counterclockwise.
Haynes: This is a snug fit.
Translation: You will skin your knuckles!
Haynes: This is a tight fit.
Translation: Not a hope in hell, bucko!
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start;
now you are looking at scary photos of the inside of a gearbox...
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a BIG can of WD40...
Haynes: Retain small spring...
Translation: "Jeez what was that, it nearly took my eye out!"
Haynes: Press and rotate to remove bulb...
Translation: "OK - that's the glass part off, now use some good pliers to dig out the base...
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing...
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One wrench rating.
Translation: Your mother could do this... so how did you manage to botch it up?
Haynes: Two wrench rating.
Translation: Now you may think that you can do this because two is a low, tiny, little number... but you also thought the wiring diagram was a map of the Tokyo underground.
Haynes: Three wrench rating.
Translation: OK - but don't expect us to ride in it afterwards!
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahaha!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at, throw at the garage wall, then search in the dark corner of the garage for while muttering "Piece of [email]Sh@t"[/email] repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife, "Yep, as I thought, it's broke!"
Haynes: Carefully...
Translation: You are about to cut yourself.
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark pugs removed.
Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: Index
Translation: List of all the things in the book but the thing you want to do!
Re: Do you have the book? [Re: BigJim] #955670 07/27/09 08:49 PM
Mike Bondi Offline
Thanks Big Jim......You made my day MUCH BETTER....Mike <img src="/forums/images/graemlins/oink.gif" alt="" />
2013 Wrangler Rubicon, 2014 Jeep Cherokee Latitude, 09 Mercedes Benz ML350 4matic...Old scooter trash trying to do good, in the flat lands of Indiana
Re: Do you have the book? [Re: Mike Bondi] #955671 07/27/09 11:57 PM
reepersteve Offline
Damn, Jim. Judging by some of those titles and nothing else. One would think you are a sick f***, looking for such books. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Do you have the book? [Re: BigJim] #955672 07/28/09 02:00 AM
DBL_DTY97TJ Offline
Still looking in the dark corner of my (not particularily mechanical) shop for some of those parts! You hit that one pretty well...Thanks for a good laugh at my mashed knuckles. Dern cheap ratchet (again) this time... <img src="/forums/images/graemlins/lol.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Do you have the book? [Re: BigJim] #955673 07/28/09 03:10 AM
sunder Offline
Thats soo true <img src="/forums/images/graemlins/lol.gif" alt="" />
Unless you are a skilled mechanic, those books give you just enough info to really get yourself in trouble... <img src="/forums/images/graemlins/angry.gif" alt="" /> I wonder if they hold stock in AAMCO or NAPA or something.... <img src="/forums/images/graemlins/evil.gif" alt="" />
91 YJ
2 Seater Sand Rail
Handfull of other fun toys...
And a brand new, spit shined, B.S.
Oh, and a job to boot.
Re: Do you have the book? [Re: sunder] #955674 07/29/09 01:57 AM
DBL_DTY97TJ Offline
Sunder....That you? Brian, moderator emeritus? Good to see you back. "Need a Spot"... <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Do you have the book? [Re: DBL_DTY97TJ] #955675 07/29/09 05:25 AM
sunder Offline
Yeah, it's me... They had a data corruption or something and I had been gone sooo long, etc... Now I'm just a regular jeep forum Joe (or Jim??), looking to get back into it.
91 YJ
2 Seater Sand Rail
Re: Do you have the book? [Re: sunder] #955676 07/30/09 02:13 AM
DBL_DTY97TJ Offline
Welcome back. You're knowledge and input have been missed. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Do you have the book? [Re: DBL_DTY97TJ] #955677 07/30/09 02:40 AM
fishtaker Offline
Welcome back Sunder. It feels good to know that I have more posts than you. I bet it won't last for long.
03 TJ 5 Speed I-6 30X9.50 BFG KO's
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6299 MB (Peak: 0.7361 MB) Data Comp: Off Server Time: 2026-10-21 17:40:35 UTC
