Grinding - Clunking - and Blinking Lights #955764 07/27/09 06:25 PM
WigWiggy Offline OP
Background: This is a gen II.5 Montero with 186k miles. I just bought it a few months ago. Came from upscale suburb of DC so the 4WD was probably barely (if ever) used.
Went for a short trip down an unmaintained west virginia 'road' and used 4-LO for the first time this weekend. The 2 front wheel lights on the dash did blink for the first few hundred feet before they stayed lit continuously, but everything worked great after that. When I was done and shifted back into 2WD the lights went off right away. I drove home 70 interstate miles with no problems and then hit some traffic. After some cycles of stopping and inching up a few car lengths at a time, I pull forward slowly and there's a loud grinding noise and shudder from the front end - like something is binding up - and then there's a CLUNK and it smooths out, but the two front 4WD dash lights come on and start blinking . I pulled off to the shoulder, shifted in to 4hi, drove forward a bit and stopped, put back into 2wd and backed up a bit (while reminiscing about my old Gen I's 4WD disengagement procedure). The lights went off when I pulled forward back out onto the road...then I hit some more traffic, and the grinding clunk blinking happened again.
I've been searching the board and already found the very helpful article about the 4WD lights/actuator system, so I know what parts to check. My question is: what is mechanically occurring to cause the noise, and why is it related to stop-and-go traffic situations? My guess would be that the front axle is partially engaging (grinding/shuddering) and then fully engaging (CLUNK) - and then the lights blink because of the discrepancy between the front axle being engaged but the transfer case being in 2HI...does that sound right? Anyone have an idea of why this would occur only in stop-n-go traffic? Any other suggestions would be much appreciated, thanks.
98 Montero, 184k.
Re: Grinding - Clunking - and Blinking Lights [Re: WigWiggy] #955765 07/29/09 05:47 PM
WigWiggy Offline OP
This got buried but I'll keep it going in case anyone finds it helpful. Blinking 4WD lights seems to be a common issue, but the grinding noise doesn't.
Is it possible that there is less vacuum pressure available when the engine is idling in traffic, allowing a borderline-weak/sticky valve to let the front axle actuator PARTIALLY "slip" into 4WD?
Found this very helpful post from Scottie2113 - it sounds like I need to look at the "yellow dot valve":
"what I have found to be the problem most of the time with this is the two little solenoid valves that operate the free-wheeling clutch actuator on the front axle. over many years they either go bad or get sticky or dirt in the moving valve part. they are located on the passenger side in the engine compartment on the top of the fender well. there should be one with a blue dot and the other with a yellow dot. if you are good at taking things apart, you can unbolt them and disconnect them and spray some cleaner through them hook the plugs back up and work them back and forth and try to clean them out, sometimes they seem to get sticky over the years. if that doesn't help, you may need to replace them. the actuator works on a vacuum system. I am pretty sure that if my memory serves me well, the yellow dot is for keeping it in 2wd and the blue dot assists at putting it in 4wd. your yellow dot solenoid is probably the culprit. keep in mind, that actuator on the front axle is already spring loaded, so at rest without vacuum, it always wants to be in 4wd mode (free wheeling clutch activated). the only thing that keeps the front axle disengauged (2wd) is the vacuum through that yellow dot actuator. when you put the truck in 4wd, it basically takes vacuum away from the yellow dotted line and applies vacuum to the blue dotted line to 'assist' in locking in the front axle free wheeling clutch. now even without the blue dotted line working, the spring load of the actuator would eventually put in 4wd, but the blue dotted line helps this process as it needs more force to go into 4wd than to come out of 4wd. i hope this helps and if I confused you let me know."
98 Montero, 184k.
Re: Grinding - Clunking - and Blinking Lights [Re: WigWiggy] #955766 07/29/09 09:39 PM
See, you found out how to fix it yourself. I think you are dead on, except for the idea on low vac at idle, where engine vac is typically high. I suspect a leaking vac line or a bad solenoid valve, or a sticky acutator gizmo...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5985 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-06-07 04:38:51 UTC
