long term high octane usage? #955829 07/28/09 02:22 AM
blitz Offline OP
car does run noticably better on high octane.just wondering if i run it all the time,are there any adverse effects.
Re: long term high octane usage? [Re: blitz] #955830 07/28/09 06:34 AM
DamKia Offline
Kia Moderator
only hip pocket ones.
Vehicle is optimized for 87 RON/MON. Running it on anything above that will not improve performance (very common ricer fallacy). There is the possibility that it will run smoother as you noted due to additives in the better quality fuels.
Re: long term high octane usage? [Re: DamKia] #955831 07/28/09 07:41 AM
blitz Offline OP
any possibility of getting more m.p.g.'s with high octane?
Re: long term high octane usage? [Re: blitz] #955832 07/28/09 01:45 PM
DamKia Offline
Kia Moderator
Marginal to none. More effect can be had by adjusting driving style and tire pressures. Bang-for-buck the net effect is it will cost you money to run high octane fuel over and above any savings you may make in fuel consumption.
Re: long term high octane usage? [Re: DamKia] #955833 07/28/09 11:57 PM
Iron Offline
The higher octane gas burns a little hotter, it helps remove build up etc! but because it burns hotter it can cause damage to the engine, especially when the engine is not designed to run on the higher octane. Ever seen whats happens when you run 105+ Drag fuel in a normal motor! smile
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6033 MB (Peak: 0.6672 MB) Data Comp: Off Server Time: 2026-06-07 04:21:51 UTC
