Max Tire size on stock 2000 Sportage rims ? 235 75R15 work? #956525 07/31/09 10:50 PM
P
patman Offline OP
I am wondering since I own 4 new 235 75R 15 tires ... will they fit on my stock 2000 Sportage with the stock cast wheels? The whole thing is stock. It is a 4 door 2WD 5 spd manual tranny (I don't think that matters...) The rear shocks are maybe 1.25 inches from the stock 205 tires and it looks close, but with the 7" stock rims I think they will fit. They are on big chevy van rims now which are maybe 8" or 9" rims which is what I measured the width on. I read somewhere that they are the largest that may fit. I hope someone here knows so I don't have to waste my time trying it. I need new rubber on the ground and I own these and need to use them. I think it would look better with them and may help my mpg some as well.
Thanks for any guidance !
I have gotten lots of help from this website. Thanks.
Patman in OKC
patcawyer@cox.net
Re: Max Tire size on stock 2000 Sportage rims ? 235 75R15 work? [Re: patman] #956526 07/31/09 11:16 PM
Hydra747 Offline
Well Mr. Pat welcome back.
YES they will fit!
Re: Max Tire size on stock 2000 Sportage rims ? 235 75R15 work? [Re: Hydra747] #956527 07/31/09 11:29 PM
P
patman Offline OP
Wow ! Thanks for the quick response. I will be glad to have new treads on the ground. I hope you are doing well this afternoon. I will get out the floor jack and get started then. I can tell they may be close on the inside especially in the rear near the shocks. I bet it will handle way different with the bigger tires and lots more new deep tread. I may go for a body lift later. I still like it like it is just fine and don't get this little 2WD off the road much, but I do like the ground clearance it has (just from the factory.)
I appreciate your help !
Patman in OKC
Re: Max Tire size on stock 2000 Sportage rims ? 235 75R15 work? [Re: patman] #956528 07/31/09 11:36 PM
Hydra747 Offline
I put in 30's on a stock 98 7 years ago ....and all I had to do was barely tap the back of the front area....(urs should be around 29)......
With ur size u are at a perfect max out! <img src="/forums/images/graemlins/kewl.gif" alt="" />
U read the sticky on tire size and lifts I suppose......
K.....hope all is well and I may put on that same tire size soon --- Wranglers <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Max Tire size on stock 2000 Sportage rims ? 235 75R15 work? [Re: Hydra747] #956529 08/01/09 12:35 AM
Nukeiridium Offline
I ran 235/75/15 on my stock Sportage before I found out there were lift kits and stuff out there. Should work fine.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: Max Tire size on stock 2000 Sportage rims ? 235 75R15 work? [Re: Nukeiridium] #956530 08/01/09 12:51 AM
Everet Offline
May need to trim the underside of the front bumper.
Would look good with a 3" lift!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Max Tire size on stock 2000 Sportage rims ? 235 75R15 work? [Re: Everet] #956531 08/01/09 07:43 AM
P
patman Offline OP
Thanks, guys ! You guys are too cool !
and MIKE, I am totally into guns and computers too. I had to quit buyin guns and reloading stuff so I could afford the parts for my new computer I just put together. I have enough of 'em anyway and I need to just reload more ammo so I can go shoot 'em. The ammo's gettin' scarce. I just bought 2000 primers yesterday so I can load up the 10mm and the 9X23 winchester I like to shoot.
I am going to switch the tires tomorrow. I may just do the lift B4 long too. Thanks for verifying that I'm not wasting my time on the 235s.
Keep the greasy side down, guys !
-Pat in OKC smile
Re: Max Tire size on stock 2000 Sportage rims ? 235 75R15 work? [Re: patman] #956532 08/01/09 11:53 PM
Hydra747 Offline
I used to build old hybrids (during the Pentium 133 mhz) days....What kind of system did u get Pat?
I still hate Vista!!!!!!!!
Anyway hope all goes well.
Everet built a Rifle Rack on the roof of his Sport.....Maybe he'll post a Pic??????? <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Max Tire size on stock 2000 Sportage rims ? 235 75R15 work? [Re: Hydra747] #956533 08/02/09 01:04 AM
Everet Offline
Here is a link to the install: Gun Rack
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6306 MB (Peak: 0.7365 MB) Data Comp: Off Server Time: 2026-11-03 12:28:50 UTC
