Overheating Sami #956601 08/01/09 02:49 PM
G
gerry_p Offline OP
I got just my new to me 1987 Sami home. It starts and runs good but temp shoots up to the red in a few minutes. Not sure the engine is really as hot as the gauge says it is but so far have replaced the thermostat, rad cap and radiator. Even took the new thermostat out and am running it without one - still very hot. What do you think - sending unit, receiving unit, head gasket, timing?? No oil in rad, no antifreeze in oil, no white exhaust. Need help.
Gerry
Re: Overheating Sami [Re: gerry_p] #956602 08/02/09 12:19 PM
4x4Wire Offline
A couple of things to check: engine timing and water pump.
Are you circulating water through the radiator?
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Overheating Sami [Re: 4x4Wire] #956603 08/02/09 03:59 PM
rascott Offline
a pressure test of the cooling system might show a leak some where(or a bad radiator cap).
also if the radiator is gummed up or missing a lot of the cooling mesh, bad coolant mix?
mabe?
oh, i see new cap.
oh- sorry- i see new radiator also.
still think a pressure test would be a good idea.....
'94 "tracker", with some parts from suzi the psychic.
other modifications made, with more to come.
some intentional.
suzitoo should get me fishing.
kj6esv
Re: Overheating Sami [Re: rascott] #956604 08/03/09 09:57 PM
G
gerry_p Offline OP
Thanks guys. A new temp. sending unit didn't change the reading. We did check the timing and it was a bit too far advanced but only a few degrees. The water pump is circulating well. But we hooked up an accessory temp. gauge and the temp. was exactly where it should have been. The gauge in the dash is not reading accurately. I don't know if the receiving unit in the dash can be replaced without replacing the whole gauge, but I think we'll just keep the accessory gauge and call it a day.
Gerry
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6047 MB (Peak: 0.6601 MB) Data Comp: Off Server Time: 2026-05-29 14:43:05 UTC
