Page 2 of 3 1 2 3
Re: suggestions on a mikuni carb replacement 87 Raider [Re: IncorpoRatedX] #956879 01/23/15 07:50 PM
cheesegrater Offline
Best advice I've seen here for 2.6 carburetor replacement.
Re: suggestions on a mikuni carb replacement 87 Raider [Re: cheesegrater] #956880 01/23/15 09:16 PM
DR1665 Offline
Preach it.
Worth mentioning, however, I've got (2) of those spiffy, fuel injected G54B intake manifolds - with fuel rails - preparing to ship from Brisbane, Australia, to Phoenix. Well, (3), actually, but one's already spoken for. <img src="/forums/images/graemlins/evil.gif" alt="" />
Brian DR1665 | GBXM | Gearheads United.
89 Raider SWB [rock] | 91 Galant VR4 [roller]
Re: suggestions on a mikuni carb replacement 87 Raider [Re: METALMOVER] #956881 01/23/15 10:03 PM
DocHaley Offline
interested, can you send pic? ready to install and use? needs nothing except installation?
if not then simply tell me what it needs.
why did you remove it? what did you go to and why?
I'm an old guy, 63, disabled, so I'm not a true mechanic.
I'm only looking for a good carb for the Raider so I can enjoy driving it around.
I'd have to trust you to shoot straight with me.
How do you want to be paid.
thanks very much.
stephen
I am in Arlington, Texas 76011
Re: suggestions on a mikuni carb replacement 87 Raider [Re: DocHaley] #956882 01/23/15 10:43 PM
BrushBuster Offline
I put a Weber 38 DGES high performance carb on my 1984 a couple of years ago.
Big performance upgrade for mine. I already had a header on it so just increased the air and fuel. I can climb with ease now, even with passengers. I can climb hills with two passengers that I could only climb by myself before.
1984 Montero, 2.6 - 5 speed, Weber 38 DGES carb, header and flowmaster no CAT, original AISIN locking hubs, 31 x 10.5 x 15 Goodyear MTR Kevlar, 3 inch body lift, KYB Shocks, 1974 Warn 8274 winch
Re: suggestions on a mikuni carb replacement 87 Raider [Re: BrushBuster] #956883 01/26/15 04:03 PM
zarktheshark Offline
I have a GM EFI Throttle body that I was going to put on mine before the motor blew. Now going a different route. New in the box. My loss your gain smile
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: suggestions on a mikuni carb replacement 87 Raider [Re: zarktheshark] #956884 01/26/15 08:01 PM
AZRaider Offline
If you want a stock, bolt in, and go carb, check here. I highly recommend them. Lifetime warranty included.
Guaranteed Carbs
1987 Dodge Raider, 2.6L, manuel, bone stock with a whole lot of new and refurbished parts. Brought back from the dead after 12yrs.
cylinder numbering ? [Re: cheesegrater] #956885 03/22/15 07:15 AM
DocHaley Offline
I was looking for the numbering of the cylinders in the 2.6 Liter engine. I'm assuming they are 1-2-3-4 from front to back (radiator to firewall) but don't really know for certain.
Anybody know?
Lastly I got the carb change out done. Put on a CW 1 bbl on my 2.6 and it started up first time and runs like a clock.
Made an aluminum adapter plate and used a 3/8" spacer.
What a relief all the emissions crap is gone.
Just have to figure out an air filter set up. 1bbl taller than the mikuni and the auto choke stick up an inch above the top of the carb.
Thanks for everyones advice.
Doc
Re: cylinder numbering ? [Re: DocHaley] #956886 03/22/15 04:28 PM
Yep, numbered front to back, 1-2-3-4.
Re: suggestions on a mikuni carb replacement 87 Raider [Re: DocHaley] #956887 04/03/15 05:18 PM
DocHaley Offline
I did mine, am an old guy, 63, disabled, yet it worked like a champ. Did not use the 32/36. Used a 1bbl. Here is a pic if I am allowed to upload.
Here is a pic of the adapter plate I made, cost $25.
I'll return with a pic of the finished carb in a minute.
Re: suggestions on a mikuni carb replacement 87 Raider [Re: DocHaley] #956888 04/03/15 05:21 PM
DocHaley Offline
Guess I can't post pics.
If any of you want a pic of the 1bbl I used on my 4 cyl Dodge Raider, 1987, just ask. fpsw69@gmail.com or through this server, but I can't post a pic here it seems. Never did anything like this before but with the advice and support lots of you guys gave me it worked just fine.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6382 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-07-10 19:20:01 UTC
