gas /fuel gague stuck on empty ... #957575 08/06/09 01:29 AM
KB2IAW Offline OP
O.K. been awhile since ive been here ...Skeet & trap has been taking up alot of my time...SOooo last week i pulled into my driveway ,put the montero in park and noticed the gas gague fell below empty (never did that before ) <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> So i get out my chiltons & my haynes ...no mention of gas /fuel gague failures .Next day i fill up just in case ...i go down the hill hit a bump ...WALA gague works again ,for a short period of time
I need ideas where to look ??what to try .or how to test .
Last resort would be drop the tank ...Any Ideas anyone ...? <img src="/forums/images/graemlins/confused.gif" alt="" />
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
Re: gas /fuel gague stuck on empty ... [Re: KB2IAW] #957576 08/06/09 03:18 AM
SandRaider Offline
My gas gauge doesn't work on my gen I swb. My problem was the electrical connections on the sending unit broke and the electrical plug wouldn't stay attached.
It might help if you tell others which model you have
Eric
89 Raider V6, 35s, 5sp, welded rear, 8k winch
89 Raider 2.6 going on 84 4runner frame
Re: gas /fuel gague stuck on empty ... [Re: KB2IAW] #957577 08/06/09 03:24 AM
Renegade Offline
I had the same problem on mine. To fix it remove the sending unit, get some gas tank cleaner from national gas tank cleaner, and soak the sending unit in it. The unit corrodes over the years and the float eventually gets stuck. If you let it soak and move the float back and forth by hand it should free it up. Be carefull of the resister wires, as you dont want to break them. The longer it soaks the better it will be. Hope this helps. Chris
87 Dodge Raider 4.3 Vortec work in progress
89 Dodge Raider 3.0 V6 Fully Restored
Links are in my Bio to Photos
Re: gas /fuel gague stuck on empty ... [Re: SandRaider] #957578 08/06/09 04:59 AM
94SR. It's in his profile.
Sorry, no idea what the cause is. I'll stay tuned though so I'll have idea's if/when this happens to mine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: gas /fuel gague stuck on empty ... [Re: off-roader] #957579 08/06/09 05:20 PM
There should be an access panel for the tank sender in the back. Get at the wire and ground it (make SURE its the sender wire, not the fuel pump wire) and see if the gauge goes full scale. If so, it's the connector or the sender.
Re: gas /fuel gague stuck on empty ... [Re: fasteddy] #957580 08/06/09 06:26 PM
KB2IAW Offline OP
I didnt know there was /is an acess panel in the rear ...The sheep dip @ the stealer /dealer said that the tank had to come down ...Thanks fast eddy for the tip ..im gonna pull up the carpet and see what i can see .
Re: gas /fuel gague stuck on empty ... [Re: KB2IAW] #957581 08/06/09 10:12 PM
Not dead sure there is on a gen2. There is on all gen1 3.0's, and I guess on all gen1 year models that had the FI, even if it has the 2.6.
Re: gas /fuel gague stuck on empty ... [Re: fasteddy] #957582 08/07/09 07:26 AM
soypajero Offline
my raider just shows when the tank is full after a few miles goes all the way to empty...
Re: gas /fuel gague stuck on empty ... [Re: soypajero] #957583 08/07/09 03:47 PM
V
vr4 Offline
there is an access panel and the tank does not need to come down. last time i pulled a pump out of a gen 2 took about 10 minutes taking my time.
amazing how many tanks i see hanging in the yards with no pumps......and the access panel still in place <img src="/forums/images/graemlins/lol.gif" alt="" />
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: gas /fuel gague stuck on empty ... [Re: vr4] #957584 08/08/09 06:50 PM
KB2IAW Offline OP
Just wanted to ad my responce to all ...Thanks very much for the ideas ..I did get access to the coverplate in the rear of the montero ...I did also locate the fuelpump and line s also the sending unit . Still dont work / respond ,I will have to check behind the instrument cluster or the fuse blocks ,of wich i have two in the 1994 rs #1 under the hood & #2under the steering wheel ...Many thanks to all for you tips ...Ill re post wheni find out the problem /and the solution .
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6353 MB (Peak: 0.7430 MB) Data Comp: Off Server Time: 2026-10-21 22:06:28 UTC
