Changing all 3 belts.....Help! Kia is taken apart & I am struggling #958300 08/09/09 09:11 PM
kellbell77 Offline OP
I have a 2001 kia sportage 4wd, and I do all my own work. Bombardji and Everet have been helpful, so any help from anyone will help me out. I am changing all 3 belts on the suv and i got the the powersteering belt, and was able to loosen it, but can't get it off or even retighten it. I got the other 2 off with the tension screw/nut and now I have this all apart, and if I can't change it, I need to at least get it tighten. Does anyone have any ideas? Any quick easy fix to this (other then just taking it off & dealing with it)? The other belts were easy but this one, no matter what angle I can't get it off, let alone tighten it, so even if I get it off and new one on, how do I tighten it back up.......Help I need this tomorrow for work and it's all ripped apart.....
I have changed the headgasket, sensors, thermostat but myself and really can't afford to take this in.
HELP>>>>>>>please!
Thank you <img src="/forums/images/graemlins/angry.gif" alt="" />
2001 Tan Kia Sportage, has a K&N air filter, Warn Hubs but there's nothing really special about it, but my 7 year old loves my KIA cuz she sits up high!
Re: Changing all 3 belts.....Help! Kia is taken apart & I am struggling [Re: kellbell77] #958301 08/09/09 09:58 PM
Ok got it. Had to take stupid bracket off that holds a pulley! I literally whipped that stupid belt down my driveway..........
Re: Changing all 3 belts.....Help! Kia is taken apart & I am struggling [Re: kellbell77] #958302 08/09/09 11:30 PM
homerdog Offline
been there done that, glad you got it fixed though
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: Changing all 3 belts.....Help! Kia is taken apart & I am struggling [Re: homerdog] #958303 08/10/09 07:10 AM
Nukeiridium Offline
I'm lazy, I don't remove anything extra. I just loosen the bottom power steering bolt, REMOVE the top power steering bolt, pull the power steering pump as far away as it will go, and then force the belt out between the power steering pulley and the bracket. It's a tight squeeze but it will fit.
Then when I replace it, I use the Duralast belt Autozone sells that has notches in it, and the notches make it easier to squeeze the belt through the gap between the pulley and the bracket.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: Changing all 3 belts.....Help! Kia is taken apart & I am struggling [Re: Nukeiridium] #958304 08/11/09 02:46 AM
i got by removing the 4 bracket bolts a bit, made enough room to squeeze it thru and worked like a charm....Taking things apart comes easy, since I have replaced the headgasket and chnaged the spark plugs 2x already by myself. But thanks........
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6093 MB (Peak: 0.6743 MB) Data Comp: Off Server Time: 2026-05-29 14:43:50 UTC
