I am at a loss #958589 08/12/09 02:00 AM
Mudslinger77 Offline OP
Please help... My 90 3.0 starts and runs for a few seconds and then shuts off. It will sart immediately back up just to go dead again... I have replaced the following: alternator, battery, cables, and ECC relay... Its getting expensive and frustrating!
1990+ Montero SWB V6 AUTO (Build in Progress)
31X11.5X15 Super Swamper TSL
15X8 aluminum wheels
1.5" suspension lift
1992 Jeep Cherokee 4.0L Auto (Build in Progress)
31X10.5X15
Stock Wheels
2.5" rear/stock front lift
fenders trimmed
Re: I am at a loss [Re: Mudslinger77] #958590 08/12/09 02:06 AM
Any error codes or check engine light (make sure the bulb's not burnt out)?
Any recent service history prior to this problem occurring?
Perhaps a clogged fuel filter?
Have no fear, I'm sure someone who's smarter at this than me will chime in soon. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: I am at a loss [Re: Mudslinger77] #958591 08/12/09 02:40 AM
Kevin C Offline
If it dies as you release the key mAke sure you have spark in the run position / power to the ignition.
What is the tach doing when it dies?
Kevin
Re: I am at a loss [Re: off-roader] #958592 08/12/09 02:42 AM
CapnCrunch Offline
Yeah, kinda sounds like a clogged fuel filter or a fuel pump that's not up to snuff. [Linked Image]
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: I am at a loss [Re: CapnCrunch] #958593 08/12/09 05:13 AM
SandRaider Offline
I was also going to suggest a fuel issue
Eric
89 Raider V6, 35s, 5sp, welded rear, 8k winch
89 Raider 2.6 going on 84 4runner frame
Re: I am at a loss [Re: SandRaider] #958594 08/12/09 10:57 PM
It's 'cause y'all live in Tennessee. It just has Big Orange fever. Nuthin' sucks like a big orange...
I'm with Kevin. Does it run after you go back to on from start, or does it just crank and die?
I'm guessing the FI control relay is bad. It has seperate on states for start and run. Start mode is ign sw controlled, and run mode is ecu controlled. The run mode may be bad.
Re: I am at a loss [Re: fasteddy] #958595 08/12/09 11:20 PM
It runs for various lengths of time after it starts.... After it starts it idles up I hear a click under the dash and it goes dead just like it runs out of fuel... Where is this FI control relay you spoke of fasteddy? Is it the same as the ECC relay which I have already replace?
31X10.5X15
Stock Wheels
fenders trimmed
Re: I am at a loss [Re: fasteddy] #958596 08/12/09 11:21 PM
joestruck Offline
Fuel filter and or water in the fuel, bad fuel pressure?
Re: I am at a loss [Re: Mudslinger77] #958597 08/12/09 11:23 PM
No issues mechanically up until this point... Just wouldnt stay running one day! I changed the fuel filter not long ago and have good fuel pressure!
31X10.5X15
Stock Wheels
fenders trimmed
Re: I am at a loss [Re: Mudslinger77] #958598 08/13/09 01:38 AM
KrzyDav Offline
I had a MPI relay go bad. Driving down the highway and "click" ( i couldn't really here it) ...dead.
I got a bad ECU code <img src="/forums/images/graemlins/confused.gif" alt="" />.
After installing my spare ECU and still nothing. Just took a lucky guess and pried the can off the relay and it was all green with corrosion.
Diamantes and Sonatas use the same relay so check the yards. I think the relay is like $75 from the dealer.
dave h.
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6397 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-11-03 13:38:23 UTC
