cross-over parts #958641 08/12/09 07:55 AM
jdmckiel Offline OP
Hey lads....just a newbie so beware :} I have a Pajero,built in November 1989 LWB /4D56 TD...Are any Montero`s a match for this year,excluding the engine of course and I don't believe the Montero had the four wheel disc brakes on their early models.I have tried to research but man alive there is considerable material too ingest.TALK AT YOU LATER......jd <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: cross-over parts [Re: jdmckiel] #958642 08/12/09 05:23 PM
PHIL_ Offline
Just double check that your chassis number starts with an L and not a V, and you should be good to go on a North American 90 or 91 Montero for parts. This is what we call a gen 1. Gen 2's started JDM production in jan/91.
Welcome to the 'Wire! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: cross-over parts [Re: PHIL_] #958643 08/13/09 01:41 AM
jdmckiel Offline OP
Yes it`s a L-149 yada yada..am I correct in regard`s the rear disc`s as I only see drum and shoes on the 90 and 91 Montero`s. Thank`s for having me
Re: cross-over parts [Re: jdmckiel] #958644 08/13/09 04:17 AM
Spider Offline
Welcome.Where in BC are you. I have an 89 shorty Pajero and my brother an 89 Raider all part can be swapped between the two. I also have a 90 Pajero parts truck if you need anything. <img src="/forums/images/graemlins/cheers.gif" alt="" />
89 Pajero 2.5 TD
Re: cross-over parts [Re: Spider] #958645 08/13/09 04:31 AM
jdmckiel Offline OP
I`m in Armstrong,the biggest issue was finding rear rotors and calipers,I had them shipped from Milnor.offroad out of England,,not an unreasonable price but the freight was a killer.I searched the net but didn`t see Montero parts that appeared to fit.I hope to change out the brakes soon and also the slave cylinder,and do the filters at the same time.If I need a part I will give you a shout and see if you have what I need,I travel to Squamish quite a bit to see my family. Cheers for now jd
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6061 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-06-23 03:11:17 UTC
