Front Differential Housing #958767 08/13/09 07:27 PM
Tcloud Offline OP
I Have a 1988 SR5 4x4 thats leaking oil from the cover on the front differential.
Is this hard to get off to replace the gaskets??
Thanks Tcloud
Re: Front Differential Housing [Re: Tcloud] #958768 08/14/09 12:13 AM
Snowtoy Offline
Suspension and Axle section from the '93 FSM listed at the top of the forum.
Re: Front Differential Housing [Re: Snowtoy] #958769 08/14/09 02:33 AM
Tcloud Offline OP
Thanks Snowtoy for the link. Do you know if I have the room to just replace the gasket on the cover with out removing the whole thing???
Re: Front Differential Housing [Re: Tcloud] #958770 08/15/09 12:10 AM
Tcloud Offline OP
Anyone??
Re: Front Differential Housing [Re: Tcloud] #958771 08/15/09 12:23 AM
OOP'S Offline
Anyone??
There is no gasket you use a good RTV that is gear oil compatable, like Toyota orange FIPG.
If I remember right if you take the front x-member off you can remove the front cover.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Front Differential Housing [Re: OOP'S] #958772 08/15/09 03:02 AM
Snowtoy Offline
Looking at mine, I would think you should be able access the lower bolts w/o removing the x-member, kind of depends on how long they are I guess. W/the cover bolts removed and the diff housing support bolt removed it looks there is enough room to slide the cover upwards to remove it. You might have to unbolt the diff from the truck so you can move it around/lower it a bit to get the cover off, but you shouldn't have to remove it. Just make sure to support the diff if you do end up completely unbolting it. It really is one of the those things that until you try you wont know what you have to do.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6076 MB (Peak: 0.6765 MB) Data Comp: Off Server Time: 2026-06-17 11:41:18 UTC
