power steering #958978 08/14/09 09:36 PM
toyT100 Offline OP
How is the power steering/ steering box supposed to be serviced? Is it just a replace item or a new fluid thing or what?
Re: power steering [Re: toyT100] #958979 08/15/09 04:40 AM
Adam F Offline
Whats wrong with it?
You can flush the fluid if its dirty. Takes ATF not power steering fluid.
You can adjust the freeplay with the screw and jamb nut on top if its excessive.
Only replace it if it doesnt work, makes grinding noises, or the freeplay is too excessive.
97 4R, stock, daily driver
Re: power steering [Re: Adam F] #958980 08/15/09 04:53 AM
CJMT100 Offline
DO NOT PUT IN POWERSTEERING FLUID..
Just wanted to make sure-you will ruin it if you do.
Re: power steering [Re: CJMT100] #958981 08/15/09 05:22 AM
toyT100 Offline OP
The play is just bad in it....Ill have to adjust the screw on top....any tips on that procedure?
Re: power steering [Re: toyT100] #958982 08/15/09 05:43 AM
Adam F Offline
Yep....loosen the large jamb nut....while holding the jamb nut with a wrench, tighten the center bolt with a flat head screwdriver. Do this a little at a time, checking free play at the wheel. You don't want to tighten it too much, there should be just a little free play. Might help to jack the front end up to make sure its not too tight...there should be no resistance.
If you tighten the bolt all the way down and theres still excessive freeplay, the box needs replaced.
Here's the FSM procedure
http://personal.utulsa.edu/~nathan-buchanan/93fsm/steering/3onvehicl.pdf
Re: power steering [Re: toyT100] #958983 08/15/09 12:16 PM
garym Offline
As far as fluid, I just bought one of those cheap meat basters that look like a giant syringe. Suck as much of the old fluid out as possible and add new. That has kept my PS working fine for 114 K miles. It works great for brake fluid in the reservoir, though buy a separate one for each kind of fluid.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: power steering [Re: garym] #958984 08/15/09 04:00 PM
Adam F Offline
Best way is to disconnect the return line, stick it in a 5 gallon bucket, run the truck, and keep pouring new fluid in the resivour until it runs clean in the bucket.
Re: power steering [Re: CJMT100] #958985 08/15/09 05:29 PM
ErikB Offline
Toyota Moderator
No it wont ruin it. However, if your seals happen to be old and on the edge already, switching fluids might cause it to start leaking, similar to what some people have found when switching engine oil to synthetic sometimes.
You can use either type of fluid in the steering if your seals are in good shape, but yes, Toyota does call for ATF.
There is also a way to adjust the play on the input shaft, but on these late model boxes it requires complete disassembly. Same goes for replacing the seal on the input shaft.
On the older style boxes you can do both w/o removing the box from the truck if you want...
http://home.4x4wire.com/erik
Re: power steering [Re: ErikB] #958986 08/17/09 07:29 AM
kewlynx Offline
x 3; stick with ATF; specifically Dextron. The cheap box store stuff will finish off your seals as mentioned. All Yotas like the good stuff. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: power steering [Re: kewlynx] #958987 08/17/09 07:26 PM
G
Greg_Canada Offline
I've run power steering fluid the past 5 years no problem, knock on wood.
89 4Runner
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6403 MB (Peak: 0.7603 MB) Data Comp: Off Server Time: 2026-05-25 14:31:04 UTC
