1994 4cyl...is it np231? #959082 08/15/09 11:46 PM
tomriddle Offline OP
is the splineage the same? plug and play with 6 cyl t-case?
94 yj 456gears, detroit locker and 30 spline axles out back, 33" bfgs
Re: 1994 4cyl...is it np231? [Re: tomriddle] #959083 08/16/09 12:22 AM
BigJim Offline
The trannys are different and not interchangable... But I think the transfer cases are the same.. Which would make the splines the same. But I MAY be corrected by someone that has ruint a case and knows for sure.
Re: 1994 4cyl...is it np231? [Re: BigJim] #959084 08/17/09 05:19 AM
sunder Offline
The Case for the 231's are the same and the spline count should be the same... But I'm not 100% sure. Luckily because the cases are the same, if the t-case input splines are different, you can swap input shafts. All you would need is a pair of good snap ring pliers.
91 YJ
2 Seater Sand Rail
Handfull of other fun toys...
And a brand new, spit shined, B.S.
Oh, and a job to boot.
Re: 1994 4cyl...is it np231? [Re: sunder] #959085 08/17/09 01:48 PM
MartySoCal Offline
Usually, Jeep XJ, TJ, and YJ 4 cylinder 231 t-cases have 21 spline inputs to match the AX-5 manual transmission. Six cylinder and 4 cylinders with automatics have 23 spline inputs, the only exception is the earlier models with a 4.0l and the AW-4 or BA 10/5 Peugoet transmissions. There are a couple different input lengths, too. As sunder said, the inputs are easily swapped.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5998 MB (Peak: 0.6553 MB) Data Comp: Off Server Time: 2026-05-29 15:15:04 UTC
