Re: TRD Supercharger IAC check-valve FYI [Re: BIGBURLYNAKEDMAN] #959275 08/25/09 03:31 PM
Mark in AZ Offline
Toyota Moderator
It might be handy to have that p/n in the Taco part number sticky. <img src="/forums/images/graemlins/wink.gif" alt="" />
Exploring in a T4R Ltd V8
Re: TRD Supercharger IAC check-valve FYI [Re: Mark in AZ] #959276 09/25/09 01:23 AM
larsdennert Offline
I am looking for this part as well. Looks like this is a good number from the dealer. Some people have been using brake booster check valves.
That and a gasket for the throttle body and I hope I'm ready for the install. I may end up cutting a gasket myself. I got a good deal on a used Gen1 unit.
Does everyone's EO sticker say EO 425-3? I didn't get a sticker but I printed the EO.
Re: TRD Supercharger IAC check-valve FYI [Re: larsdennert] #959277 09/25/09 06:53 PM
BIGBURLYNAKEDMAN Offline OP
Well now that you've got the part number for the check valve, you're good to go. Should only cost you a few bucks. As for the TB gasket, that will be a little harder to order from the dealer - they'll typically only sell it to you as part of an expensive "Supercharger install kit."
I ordered my new gasket from URD for $4.95. Check this out:
http://www.urdusa.com/product_info.php?c...5dbl0p4q4b1lo47
Good luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: TRD Supercharger IAC check-valve FYI [Re: BIGBURLYNAKEDMAN] #959278 09/26/09 08:15 PM
larsdennert Offline
I got a brake booster check valve from an auto parts store. Beats having to order the Toyota part and waiting. The key is your tip on which way it goes: air blocks to the Throttle Body. Big thanks. Install is going ok. The work was getting all the other stuff off and remembering where it goes. Took pix just in case the alzheimer's kicks in again. Wait, what was I doing?
Gotta change an inside drive axle boot, install tranny cooler and change oil too. Better get to it.
Re: TRD Supercharger IAC check-valve FYI [Re: larsdennert] #959279 09/28/09 01:35 AM
G
Greg_Canada Offline
Ordered the part 3 weeks ago, toyota says delivery date, october 17... geez.
89 4Runner
PHP: 7.4.33 Page Time: 0.820s Queries: 16 (0.006s) Memory: 0.6154 MB (Peak: 0.6972 MB) Data Comp: Off Server Time: 2026-10-24 08:20:11 UTC
