tranny bolts #959424 08/18/09 02:07 PM
L
Lor Offline OP
I'm taking out the tranny on the 2.6l engine. I'm having trouble with the upper bolts. Those of you that did this work before, what's the best way to get to these bolts? From top of engine or under? Thanks.
Re: tranny bolts [Re: Lor] #959425 08/18/09 02:12 PM
87Montero Offline
Automatic or Manual trans?
On the manual trans, we always dropped the cross members and had it on a trans jack, but let the transmission come down some so we could easily get to the top bolts from below.
Re: tranny bolts [Re: 87Montero] #959426 08/18/09 02:45 PM
L
Lor Offline OP
Ah, so kinda tilt the tranny. Good tip. Keep it coming.
It's the manual tranny.
Re: tranny bolts [Re: Lor] #959427 08/18/09 06:55 PM
With a 2" BL you can pretty much reach them- been there <img src="/forums/images/graemlins/smile.gif" alt="" />. With no BL, they talk about long extensions stacked and with a wobbler. Took mine to a 1" BL and haven't had to do yet, so don't know there.... (fingers crossed) <img src="/forums/images/graemlins/baby.gif" alt="" />.
Re: tranny bolts [Re: MontyMcV] #959428 08/18/09 08:31 PM
The tranny drop is the way to go. I like removing the tcase for better drop and access.
Re: tranny bolts [Re: fasteddy] #959429 08/18/09 09:24 PM
L
Lor Offline OP
So if I do a t-case drop, what will I expect? Fluid flushing out? Gasket? (I bought a tranny gasket set, so might be ok.) Gear/seals to replace? Sorry for all the questions. I haven't dealt with tranny before.
Re: tranny bolts [Re: Lor] #959430 08/19/09 02:45 AM
Drain the fluid to make the t-case lighter. There is a procedure for removing the roll-pin on the shift fork. Basically, want to be sure you don't drop the pin into the t-case.
Do you have the FSM?
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6129 MB (Peak: 0.6902 MB) Data Comp: Off Server Time: 2026-07-16 08:51:46 UTC
