GEN 3 IDLE LOW/ A/C
#959486
08/18/09 10:45 PM
I have a 03 Montero The truck ran fine. I haven't used it for a month the Battery died which I was going to replace anyway it was the original. now the A/C stopped working the compressor kicks on by Dull air is blowing out, Also the idle is real low it sometimes stalls when I'm making a turn from a stop light. Any help with the A/C and the idle?
2003 Montero Limited White 2001 Montero GLS Diesel 1990 Montero Black Off Road Package. 1990 Montero Parts Truck.
Re: GEN 3 IDLE LOW/ A/C
[Re: koolaid6666]
#959487
08/19/09 02:04 AM
replace the expansion valve in the a/c
[Re: mxmikie]
#959488
08/19/09 02:59 AM
replace the expansion valve in the a/c Oh Ok Would that effect the Idle? I'm going to try to get that part.
[Re: koolaid6666]
#959489
08/19/09 03:05 AM
Do I have two Of Them? It calls for a front and back..
Never changed one before.
[Re: koolaid6666]
#959490
08/19/09 03:14 AM
The rear A/C is a completely self-contained unit powered by an electric motor...it may have it's own expansion valve but it will NOT affect the front. Now the heat in the rear does steal water from the front, so if you ever have coolant disappearing it's the plastic "T" that feeds the rear...common to have them crack.
As for your low idle, very common problem after the battery dies or is disconnected. The computer has to re-learn EVERYTHING, even how to wipe it's ass again! Look for the "re-training" procedure on here in past posts/tech stuff.
Hey, at least it's not your compressor...it's $750!
1989 Raider SWB Auto 3.0L...It's ALIVE! Currently on a shakedown cruise...
[Re: dougl3nc]
#959491
08/19/09 10:29 AM
Thanks Guys for the Help. ordering the part today..
[Re: koolaid6666]
#959492
08/19/09 02:27 PM
I still want to buy the GLS off of you!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6136 MB (Peak: 0.6919 MB) Data Comp: Off Server Time: 2026-06-10 01:36:11 UTCValid HTML 5 and Valid CSS
