GEN 3 IDLE LOW/ A/C #959486 08/18/09 10:45 PM
koolaid6666 Offline OP
I have a 03 Montero The truck ran fine. I haven't used it for a month the Battery died which I was going to replace anyway it was the original. now the A/C stopped working the compressor kicks on by Dull air is blowing out, Also the idle is real low it sometimes stalls when I'm making a turn from a stop light.
Any help with the A/C and the idle?
2003 Montero Limited White
2001 Montero GLS Diesel
1990 Montero Black Off Road Package.
1990 Montero Parts Truck.
Re: GEN 3 IDLE LOW/ A/C [Re: koolaid6666] #959487 08/19/09 02:04 AM
mxmikie Offline
replace the expansion valve in the a/c
Re: GEN 3 IDLE LOW/ A/C [Re: mxmikie] #959488 08/19/09 02:59 AM
Oh Ok Would that effect the Idle?
I'm going to try to get that part.
Re: GEN 3 IDLE LOW/ A/C [Re: koolaid6666] #959489 08/19/09 03:05 AM
Do I have two Of Them?
It calls for a front and back..
Never changed one before.
Re: GEN 3 IDLE LOW/ A/C [Re: koolaid6666] #959490 08/19/09 03:14 AM
dougl3nc Offline
The rear A/C is a completely self-contained unit powered by an electric motor...it may have it's own expansion valve but it will NOT affect the front. Now the heat in the rear does steal water from the front, so if you ever have coolant disappearing it's the plastic "T" that feeds the rear...common to have them crack.
As for your low idle, very common problem after the battery dies or is disconnected. The computer has to re-learn EVERYTHING, even how to wipe it's ass again! Look for the "re-training" procedure on here in past posts/tech stuff.
Hey, at least it's not your compressor...it's $750!
1989 Raider SWB Auto 3.0L...It's ALIVE!
Currently on a shakedown cruise...
Re: GEN 3 IDLE LOW/ A/C [Re: dougl3nc] #959491 08/19/09 10:29 AM
Thanks Guys for the Help.
ordering the part today..
Re: GEN 3 IDLE LOW/ A/C [Re: koolaid6666] #959492 08/19/09 02:27 PM
dougl3nc Offline
I still want to buy the GLS off of you!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6121 MB (Peak: 0.6902 MB) Data Comp: Off Server Time: 2026-06-07 05:35:12 UTC
