Where does your temp guage sit? 3.4L #959522 08/19/09 03:04 AM
kewlynx Offline OP
During our shakedown trip with the Taiga Taco, I noticed the temp guage stayed just about the 1/2 way point. The camper weighs about 1060 lbs, airbags bumped up a tad.
I pulled the camper off, so the RV shop could redo the PO's installation (off kilter), and drove the truck unladen, with the same results; about a needle width past halfway.
I don't know if he put a 195dg t'stat in there; might've. Gets pretty dang cold down in Delta, where I got the truck from.
I also suspect he's mixed green stuff with the Toyota Red, as the truck had just under 42K when I bought it. I'll be doing a flush pretty soon; just wanted to know what you guys were lookin' at with your 3.4's, which is a new mill for me!!
Thanks!
**ubi apis- ibi salus**
Re: Where does your temp guage sit? 3.4L [Re: kewlynx] #959523 08/19/09 03:35 AM
RichinROA Offline
On the dash..ba dump bump.
Honestly...about a needle width below half...no load, cept my fat butt. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
Re: Where does your temp guage sit? 3.4L [Re: RichinROA] #959524 08/19/09 06:54 AM
humanoid Offline
Should sit about half way, maybe just a tad above half.
Re: Where does your temp guage sit? 3.4L [Re: kewlynx] #959525 08/19/09 01:19 PM
Dandeman Offline
Toyota Moderator
Mine sits halfway.....
Re: Where does your temp guage sit? 3.4L [Re: Dandeman] #959526 08/19/09 03:14 PM
Mark in AZ Offline
Toyota Moderator
Same here, a needle width below half, and never changes from load or outside temps. The engineers got this right.
Exploring in a T4R Ltd V8
Re: Where does your temp guage sit? 3.4L [Re: kewlynx] #959527 08/19/09 07:00 PM
G
Greg_Canada Offline
Thanks!
Do you have a scangauge? leave it hooked up and it will tell you your ACTUAL temps, not what the gauge is reading. Mine stays at half or just below as well.
Also, if red+green mix, you'd be in for a rad or HG failure... happened when my cousin sold his taco...
89 4Runner
Re: Where does your temp guage sit? 3.4L [Re: Greg_Canada] #959528 08/20/09 01:00 AM
kewlynx Offline OP
No scan guage. Thanks for the reminder tho- base auto hobby shop has a temp gun.
Yeah-----I'm flushing the system pretty soon, AND doing a leakdown check just to be on the safe side. That would SUCK to have a mill with 42K on it and an HG issue.
Re: Where does your temp guage sit? 3.4L [Re: kewlynx] #959529 08/20/09 04:13 AM
Adam F Offline
Mine sits between 1/4 and halfway.
Twice it has started to overheat, at about 3/4 of the way before I shut it down. Both times it happened after pulling my boat, and then sitting at the loading dock for 15 minutes with the A/C pumping and 90+ degrees outside. I'm thinking about adding an external trans cooler. I'd highly reccomend you doing the same. I think the trans is getting hot, and since the radiator cools the trans fluid through the coolant, it starts overheating.
97 4R, stock, daily driver
Re: Where does your temp guage sit? 3.4L [Re: Adam F] #959530 08/20/09 04:26 AM
kewlynx Offline OP
Adam, the Taiga is a 5 speed, not an auto, FWIW, unless they've started plumbing them that way. <img src="/forums/images/graemlins/barf.gif" alt="" />
I'd have to be a little old lady with bad knees to buy a truck with AT. <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: Where does your temp guage sit? 3.4L [Re: kewlynx] #959531 08/20/09 02:16 PM
G
Greg_Canada Offline
I think she just called you out adam.
LOL.
89 4Runner
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6437 MB (Peak: 0.7635 MB) Data Comp: Off Server Time: 2026-10-24 13:01:48 UTC
