Noisey springs. #960202 08/23/09 08:23 PM
David1 Offline OP
Has anyone found a solution to squeeky leaf springs? I was told to put the truck on a lift and to apply some white lithium grease between the springs. This is only a temporary fix and I'm looking for something to solve the problem permanately. I know that Tacoma's are known for this defect. Thanks for any help.
Re: Noisey springs. [Re: David1] #960203 08/24/09 04:24 AM
Adam F Offline
Go to tractor supply and buy some graphite based "EZ Slide" paint. Paint each leaf with this and it will fix it.
http://www.tractorsupply.com/webapp/wcs/...rue&cFlag=1
97 4R, stock, daily driver
Re: Noisey springs. [Re: Adam F] #960204 08/26/09 05:17 AM
David1 Offline OP
Thanks for the reply Adam. I take it that you have used EZ Slide. How long does it last? Did you do any sanding prior to applying EZ Slide? I might have a few more questions regarding this, I hope you don't mind.
Re: Noisey springs. [Re: Adam F] #960205 08/26/09 05:03 PM
Adam F Offline
No, I've never used it. Never had the need, my springs have never made any noise.
But I did read on 4crawler's page that he used a simmilar product, and I saw the EZ slide on the shelves at Tractor Supply.
If I were to do it, I would dissasemble the leaves, use a grinder and completely remove any paint on the leaves. Good prep will make the paint last longer.
Re: Noisey springs. [Re: Adam F] #960206 08/26/09 07:54 PM
David1 Offline OP
Do you have a link to 4crawler's page stating what product he used on his springs?
Re: Noisey springs. [Re: David1] #960207 08/27/09 04:06 PM
Adam F Offline
He just briefly mentions that he used slip plate
"then painted everything with two coats of Slip Plate graphite paint"
http://www.4crawler.com/4x4/4R_suspension-III.shtml
4Crawler is a member of this board, you could PM him or do a search for his posts, I know he has mentioned it, and would be glad to help you out.
Here is his profile, with contact info
http://www.4x4wire.com/forums/showp...&page=1&what=showmembers
Re: Noisey springs. [Re: Adam F] #960208 09/08/09 01:48 PM
David1 Offline OP
I've decided to replace the leaf springs. Any recommendations on aftermarket brands?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6201 MB (Peak: 0.6944 MB) Data Comp: Off Server Time: 2026-05-29 15:21:19 UTC
