Re: front end noise
[Re: budicexxx]
#960259
09/07/09 01:34 PM
Do I need to separate the hub and rotor from the knuckle?
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress. 2011 Kia Forte EX
Re: front end noise
[Re: homerdog]
#960260
09/07/09 07:16 PM
Any suggestions on getting the nut off the control arm?
Re: front end noise
[Re: homerdog]
#960261
09/07/09 09:33 PM
Any suggestions on how to get the remains of the bearing out?
Re: front end noise
[Re: homerdog]
#960262
09/07/09 09:38 PM
i used a flat csrew driver that i hit with a file to make it have a better edge to get between the wall and bearing race and go around it all the way then cut it in half poped right out.
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: front end noise
[Re: jays2001]
#960263
09/07/09 09:41 PM
I'll try that, been using a chisel and no luck, been at it for 5 hours now trying to get the thing fixed and the bearing wasn't in that bad of shape so it's probably something else.
Re: front end noise
[Re: homerdog]
#960264
09/07/09 11:12 PM
oh well, that was a waste of a perfectly good afternoon
Re: front end noise
[Re: homerdog]
#960265
09/08/09 12:02 AM
your needle bearing was in good shape? Remeber there is another one...lol
Re: front end noise
#960266
09/08/09 12:36 AM
There is no need to remove the tie rod. I didnt and for the race of the bearings one of the bearing has a bigger lip than the other knock that one out first with a hammer and a punch then have some one smooth sailing for the other one. The needle bearing i tapped it with a sharp chisel and it broke right out.
2001 sporty, tj rear springs with rav4 shocks, ford alloys machined centers with 30x9.5x15, front spacers. more upgrades to come.
Re: front end noise
#960267
09/08/09 01:02 AM
Thing is that I can lock in the right side and hear the noise. If I lock in just the left side I don't hear it. Sounds like I'm hitting a speed bump. Maybe the halfaxle is shot, I'll try that next, it's got a tear in the boot anyways.
Re: front end noise
[Re: homerdog]
#960268
09/08/09 01:35 AM
that was the samething with mine and it was the needle bearing
