Page 3 of 3 1 2 3
Re: California Smog - need help [Re: RocLimer] #960379 08/27/09 07:06 PM
kela Offline
RocLimer,
Here's a link to my troubles with poor performance & CA smog issues:
http://www.4x4wire.com/forums/showflat.p...rt=all&vc=1
Kela
'90 Gen 1 Montero LWB (Original owner, daily driven x 32 yrs and counting)
400k+ miles & still going strong !!!
Re: California Smog - need help [Re: kela] #960380 08/28/09 01:45 PM
MartySoCal Offline
08-22-09 Follow-Up Test
Test RPM CO2 O2 HCmx HCmea COmx COmea NOmx NOmea
15mph 1969 13.9 1.6 118 62 0.68 0.00 999 3102
25mph 1939 14.5 0.8 98 42 0.87 0.00 859 2455
Result - GROSS POLLUTER/GROSS POLLUTER
There's a possibility that the converter was not fully warmed, but from the readings, especially ar 25 MPH, I'm seeing O2 left over with HC present, and the CO2 readings are showing good mixture control along with high NOX, I'd almost bet money that the Cat-Con is inop.
"...10-22-07...Followed this test with new high flow catalytic converter..."
These are the units with the high failure rate for NOX because they skimped on material, especially the Rhodium that catalyzes the NOX. Usually these had a two year gaurantee, at best. The new CA legal replacements must meet OEM specs, have a CARB EO# and have to carry a 5 year warranty.
Hope this helps!
Re: California Smog - need help [Re: MartySoCal] #960381 08/28/09 04:04 PM
RocLimer Offline OP
Are the Bosal OE models just as good or should I just let the muffler shop put something on as they would probably be held to selling these units which are Cal CARB compliant.
Just purchased a new oxygen sensor as well and installing it as soon as it arrives.
Also thinking of replacing the fuel filter. Any recommendations?
<img src="/forums/images/graemlins/patriot.gif" alt="" />
1989 Montero 2-Dr 3.0L V6 15X8 ProComp 97 Series w 30.5x9.5 Cooper M/T's
http://www.cardomain.com/ride/3143932
Re: California Smog - need help [Re: RocLimer] #960382 08/28/09 05:33 PM
kela Offline
Muffler shop replaced my cat converter with a Magna Flow brand converter...~$250 installed
Magna Flow Catalytic Converter link:
http://www.car-sound.com/
Re: California Smog - need help [Re: kela] #960383 08/29/09 03:43 PM
MartySoCal Offline
They should have installed part # 39004 from their website, the list price is $376.81 and fits most Monteros from '83 to '95. Make sure the converter has the part number and CARB EO# stamped on the shell, your warranty should be for 5 years.
http://www.car-sound.com/02product/displayuniversal01.asp?catalogid=55516&universal=39004
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6129 MB (Peak: 0.6946 MB) Data Comp: Off Server Time: 2026-10-24 03:11:17 UTC
