Signal Lights - Electrical Issues #960507 08/25/09 05:44 AM
G
gerry_p Offline OP
1952 M38 with a Buick V6. I was driving along and the signal lights failed to work. Checked all lights and the 4 way flashers and brake lights didn't work either. Turns out the main harness coming down the steering column came apart, but when I hooked it back up everything works except the signal lights. The bulbs are good, replaced the flasher and they still don't work. I wanted to take apart the signal light arm on the steering column but I can't figure out how to take it apart. The column is likely out of a mid 1970's CJ with tilt steering. Any suggestions?
Gerry
Re: Signal Lights - Electrical Issues [Re: gerry_p] #960508 08/25/09 03:07 PM
BigJim Offline
If it looks like this one it is a 77 and later switch. About 35 bucks on the internet..
[img][image]http://img.photobucket.com/albums/v231/BigJimM/Picture1-6.jpg[/img][/image]
Re: Signal Lights - Electrical Issues [Re: BigJim] #960509 08/25/09 06:18 PM
G
gerry_p Offline OP
Thanks Jim,
So how do I take apart the steering column to get at this switch and wiring bundle. This column has also has a mechanism at the top to prevent auto theft. You insert a key in the slot, push down a lever and the steering wheel comes off. When I do that, there are four "star" fasterers, but they just keep spinning when I turn them, without coming undone.
Gerry
Re: Signal Lights - Electrical Issues [Re: gerry_p] #960510 08/25/09 06:55 PM
BigJim Offline
Thanks Jim,
Gerry
Gerry you have completely lost me.. Got a photo you can post? Perhaps someome else on here knows what that device is.. I never saw one that I am aware of.. Does it have a NAME written on it that I can Google?
Re: Signal Lights - Electrical Issues [Re: BigJim] #960511 08/26/09 12:23 AM
G
gerry_p Offline OP
Jim, this Vehicle Security Device is made by Grant - the same outfit that makes after-market steering wheels. It allows you to take off the steering wheel to help prevent theft. I did find their website and sent them an email asking for a diagram on how this stuff comes off the column. I haven't got a response yet. It's actually a slick system. You turn a key (separate from the ignition system), push down a lever and then remove the wheel. Replace the wheel with a special cap that locks in place to keep the rain out. I have no top on the jeep and it would be very easy to steal.
Gerry
Re: Signal Lights - Electrical Issues [Re: gerry_p] #960512 08/29/09 08:10 PM
G
gerry_p Offline OP
Jim was right. I had to buy some special tools to get the steering column apart - I had a couple of damaged wires that had corroded so I fixed those and cleaned up the switch - it had lots of crud in there. Everything works. Thanks everyone.
Gerry
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6097 MB (Peak: 0.6802 MB) Data Comp: Off Server Time: 2026-11-03 13:25:24 UTC
