Raider V6 Idler pulleys?
#960666
08/26/09 04:33 AM
I just recently got an 89 v6 raider. The serpentine idler pulleys under the alternator are whirring, but I don't see these idlers at any of the usual parts sites nor rock auto. Anyone got a source for these, or perhaps is there a standard size bearing that can be pressed in the pulley? Thanks Mike
89 v6 Raider 5spd 89 v6 Montero auto 86 TD Trooper
Re: Raider V6 Idler pulleys?
[Re: mike71800b]
#960667
08/26/09 04:40 AM
MY 89 is running on 89 dodge caravan v6 idlers .and a few washers in the back ..Napa brand ,,can get you a number if you cant find them ..
[Re: haztoys]
#960668
08/26/09 04:45 AM
I have bad idlers too, but I am going to take one of mine off and see if I can match up with a Ford vehicle product. I am hoping Mustang ones match so I can order Billet pulleys for my Montero. <img src="/forums/images/graemlins/mrt.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#960669
08/26/09 05:01 AM
"napa 38042 nbh backside idler pulley" ...is what my paper work says ..
[Re: haztoys]
#960670
08/26/09 06:52 AM
My mechanic just replaced mine. I could be wrong but I think he got the parts from Mitsubishi.
1989 Mitsubishi Montero SWB V6. Torsion bar crank, Gen II springs, 31X10.5" BF Goodrich M/T's 2005 Mitsubishi Montero Limited 3.8 V6 2011 Subaru Impreza Outback Sport
[Re: 89Montiero]
#960671
08/26/09 07:20 AM
Is it these ones? ![[Linked Image]](http://img22.imageshack.us/img22/8268/alternatorpulley.jpg)
 Karma's Law - For every action there is a multiplied reaction! 93 Pajero GLS 3.0 V6 LWB - SOLD 2001 Gen3 Di-D LWB - SOLD 2005 Touareg R5 2.5 TDi
[Re: 4ePikanini]
#960672
08/26/09 05:53 PM
Goodyear makes a good one, too. Search my username and "goodyear" and you should get a part#, or look at FrankR's supercharged v6 post for the billet pulleys he got. The goodyears require 4-5 flat washers for proper spacing from the bracket...
[Re: fasteddy]
#960673
08/27/09 05:35 AM
Try your Dodge dealer, too. I bought a set for my Montero about 3 years ago. No problem and they were cheaper than the Mitsu dealer, who really didn't want to talk to me anyway.
1987 Raider 1991 Montero LS Nipomo, CA
[Re: Montero_Jim]
#960674
08/27/09 08:24 AM
Goodyear Gatorback, that is the name they use on all the belts and belt-related hardware., I just threw out the box last week, I put pix up when I did it...That was about a year ago.
[Re: joestruck]
#960675
08/27/09 04:05 PM
If not contact hazy_daze (Larry), he got them for my wife uncle and they are working like a dream. They are so easy to replace that will take you just 5 minutes to do.
You only need a 12mm for the adjustment bolt and a 14mm for the pulley's nut.
Loose the adjustment bolt and remove the pulley's nut, place new pulleys in and bolt them back in then the adjustment bolt.
Done, it is that easy.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
