Need some Plenum removal direction #960831 08/27/09 01:43 AM
brubren3815 Offline OP
Don't want to pay the stealer $400 to change my pcv on the 93 3.0 12v. What a STUPID design!!! <img src="/forums/images/graemlins/evil.gif" alt="" /> Are there any tricks, impossible to reach blots, or general suggestions to make this a painless as possible? My mechanic ability is on the low side of medium. I'm not afraid to jump in and get at it but figured i'd ask here first. Also as long as the plenum is off are there any other things that I might look at or fiddle with?
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around
95 LS-- Dual Bouncy Seats 234k and still rockin'
Re: Need some Plenum removal direction [Re: brubren3815] #960832 08/27/09 05:42 AM
8
89IsMine Offline
Read through the first couple of sections of Valve Stem Seal Replacement Procedure to get an idea of what's involved. The nut closest to the firewall can be a real bugger to get at, especially to replace. I've had good success using one of those telescoping magnet part retriever... things (Yeah, it must be a technical term <img src="/forums/images/graemlins/cyclops.gif" alt="" />) to get it started. Also, when all the bolts/nuts are removed you may need to work the heater hose a bit to gain room to get the plenum all the way off the back stud -- it's got a weird little tab that hangs up on the hose.
Let's see, what else? If you've got an EGR (and I'm not sure you do with that year) be very careful of the pipe with the accordion-like portion in the middle. That area tends to fatigue and crack easily over the years and I'm told they are hard to find and/or replace.
Good luck with it. I agree... it's a stupid design and a pain-in-the- <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> just to replace the PCV valve, but it's not too difficult!
Eric W.
Re: Need some Plenum removal direction [Re: 89IsMine] #960833 08/27/09 12:38 PM
sparkem Offline
There is a bolt right behind the throttle body that you cant really see.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5946 MB (Peak: 0.6493 MB) Data Comp: Off Server Time: 2026-06-22 06:11:44 UTC
