4JB1 and 4JG2 diesel parts thread #961051 08/28/09 06:57 PM
A
acy76 Offline OP
Hello all --
I thought it would be a good idea to get a thread going listing part numbers and parts sources for these engines, as there are now a few members who own them. If you have any information, please add a response. I will add what I've got in the next day or so, as soon as I can dig it up.
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: 4JB1 and 4JG2 diesel parts thread [Re: acy76] #961052 08/31/09 02:19 AM
bellavesus Offline
4jb1t parts list
**rear main seal:
isuzu part#894214-9130
**front main seal:
napa part#NOS 19619
**cam seal:
napa part#NOS 550232
**alt belt:
napa part#22410
(was the same as the 2.2 diesel)
**power steering belt:
(i got rid of the AC so the belt was shorter)
napa part#A44
**timing belt:
gates part#5306
quinton hazellpart#QTB337
autolinkuk was my source
website with all application listings:
http://www.sct-germany.de/Catalogue/Belts_SCT/131.html
**glow plugs:Quality replacement glow plug to
OEM spec, part no. 8-94175158-0
ADZ91802, J5719002. NI00022. 8941751580.
autolinkuk, i got NI00022
seems rockauto has em now too,NGK Part #
7995 {#Y904M1}
**water pump:
QUINTON HAZELL Part # QCP3236
rockauto
**clutch kit:
VALEO#H1031N
from sunbury.au
86 Turbo Diesel 4dr Trooper 4JB1TC
89 turbo diesel Trooper-RED
Re: 4JB1 and 4JG2 diesel parts thread [Re: bellavesus] #961053 10/29/09 04:26 AM
A
acy76 Offline OP
The clutch kit mentioned in the last post does not include a pilot bearing. In replacing my clutch, I found that the 4JB1-T pilot and throwout bearings are the same as those used on the 4ZE1 gas engine.
NAPA had the pilot bearing for $3.29 (1988 Isuzu Trooper was the model I gave them).
Re: 4JB1 and 4JG2 diesel parts thread [Re: acy76] #961054 11/22/09 01:21 AM
A
acy76 Offline OP
I may be late to the party on this one, but I just checked rockauto.com and the 1988 Trooper category now has the 4JB1 listed! Unless I am missing something, all sorts of parts are now easily obtained.
Anyone have thoughts/confirmation on this?
EDIT: It looks like they want to charge international shipping when checking out, so it may or may not be a cheaper alternative to ordering from an overseas vendor. The clutch I ordered from Oz would have been about the same price, either way - and it seems like the Oz unit is heavier-duty.
Re: 4JB1 and 4JG2 diesel parts thread [Re: acy76] #961055 11/27/09 04:15 AM
A
acy76 Offline OP
The 4JB1 clutch slave cylinder can be rebuilt using the kit for the 4ZE1 (gasoline) engine - I ordered the kit for a 1988 Trooper.
The piston is the same, but the diesel spring is heavier so I reused it. The aftermarket rubber boot fit, too.
The issue is that the castings are different. Innards are mostly the same.
Re: 4JB1 and 4JG2 diesel parts thread [Re: acy76] #961056 06/11/10 09:24 PM
bellavesus Offline
4JB1T info:
i think that you could use the 2.8 rodeo clutch since it uses the MUA tranny, and even upgrade to the 3.1 rodeo clutch since it is an upgrade that many rodeo offroaders use. if/when i need to replace this aussie one, ill try the 91-91 rodeo 3.1 clutch.
oil filter part number on filterbarn.com:
LF3528
Re: 4JB1 and 4JG2 diesel parts thread [Re: bellavesus] #961057 06/14/10 09:36 PM
bellavesus Offline
part # for injection pump gasket kit 4jb1t
zexel gasket kit
GK1466-1120
Re: 4JB1 and 4JG2 diesel parts thread [Re: bellavesus] #961058 06/16/10 04:42 PM
A
acy76 Offline OP
Rockauto seems to be able to get some of the parts above from Europe - shipping is expensive, but searching by part number allowed me to add both a timing belt and water pump to my cart.
I should also add that the power steering & AC belt is the same as the one used on the 2.2l C223 diesel (1986 Trooper diesel).
Re: 4JB1 and 4JG2 diesel parts thread [Re: acy76] #961059 06/28/10 05:29 PM
P
PLammer Offline
Been a while since I made it over here, Here's what I can add for the 4JG2:
Valve cover gasket 897349416-0
Timing Belt 894380679-0
Oil Filter 897329911-0
Re: 4JB1 and 4JG2 diesel parts thread [Re: bellavesus] #961060 06/29/10 10:49 PM
JLEMOND Offline
4jb1t parts list
**rear main seal:
THIS REAR MAIN SEAL IS SUPERCEDED TO 894235-3690
WHICH IS THE SAME SEAL AS THE 2.3 AND THE 2.6 GAS ENG , FRT SEAL MAY BE SAME IF SOEM ONE CAN SUPPLY THE FACTORY NO,S BE GLAD TO CHECK FOR SUPERCESSIONS JERRY
**front main seal:
napa part#NOS 19619
**cam seal:
**alt belt:
napa part#22410
napa part#A44
**timing belt:
gates part#5306
7995 {#Y904M1}
**water pump:
rockauto
**clutch kit:
VALEO#H1031N
from sunbury.au
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6442 MB (Peak: 0.7653 MB) Data Comp: Off Server Time: 2026-06-10 07:23:34 UTC
