Re: 4JB1 and 4JG2 diesel parts thread
[Re: JLEMOND]
#961061
05/14/11 01:25 AM
oil filter that is a 26mmx1.5 Cross References AC-DELCO: PF2197 ALLIANCE: ABP/N10G-LF3746 BALDWIN: BD7095 BIG A: 92809 CARQUEST: 85809 DONALDSON: P557382 FLEETGUARD: LF3746 FLEETGUARD: LF3918 GENERAL MOTORS: 25313735 HASTINGS: LF457 LUBER-FINER: LFP2268 NAPA: 1809 THERMO-KING: 11-7382 WIX: 51809
86 Turbo Diesel 4dr Trooper 4JB1TC 89 turbo diesel Trooper-RED
[Re: bellavesus]
#961062
07/31/11 05:27 PM
I bought the Napa/Wix variant you mention, and while it looks like the center hole is correct, the gasket diameter and drainback hole circle diameter are much narrower than the Isuzu filters I've been using.
I have not actually tried fitting it to see whether this makes any difference, but it is definitely not exactly the same, unfortunately.
[Re: acy76]
#961063
02/07/12 05:15 AM
I have been using the NAPA 1809 for years on my Bighorn. Here are some parts I have been able to buy locally (in BC, Canada) Alternator-water pump belt: NAPA 25-22405. This is a nice fat 17mm belt. Alternative: Good Year Hi-Miler 22404 (15x1015mm)
Aircon-P/S belts: Good Year Gatorback 13AV1525 17601 Matchmaker
Alternator parts: Voltage Regulator: Transpo IH252 Diode Assembly: Renard 31-8133 (also says 2964 Wetherill Associates Inc on the box)
Valve cover gasket: 8973494161 This is indeed the correct one and available from Klassen Diesel $30 a shot!
Fuel Filter NAPA GOLD 3128
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.5995 MB (Peak: 0.6689 MB) Data Comp: Off Server Time: 2026-07-16 03:39:51 UTCValid HTML 5 and Valid CSS
