Page 1 of 3 1 2 3
offset on gen1 running 31x10.5x15's on 15x8 rims? #961123 08/29/09 07:32 PM
W
wugwump Offline OP
going to be getting some soft 8's in 15x8 from summit, several options with the monty's bold pattern ... what's the offset to use?
91 two-tone LWB 5-speed, sunroof, third row seat, 31" wrangler authority's on black cragar soft 8's.
Re: offset on gen1 running 31x10.5x15's on 15x8 rims? [Re: wugwump] #961124 08/29/09 09:19 PM
K_Raider Offline
http://www.4x4wire.com/forums/showflat.p...rue#Post1155809
Use the search. Theres tons more. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: offset on gen1 running 31x10.5x15's on 15x8 rims? [Re: wugwump] #961125 08/30/09 01:46 AM
Grasscat Offline
Check the first post on this page.
Michael j
TreadLightly! Trainer
Re: offset on gen1 running 31x10.5x15's on 15x8 rims? [Re: Grasscat] #961126 08/30/09 04:01 AM
powerRam50 Offline
3.75 back spacing works great.
Re: offset on gen1 running 31x10.5x15's on 15x8 rims? [Re: powerRam50] #961127 08/30/09 04:50 AM
SandRaider Offline
That's what I use, even works with my 35s
Eric
89 Raider V6, 35s, 5sp, welded rear, 8k winch
89 Raider 2.6 going on 84 4runner frame
Re: offset on gen1 running 31x10.5x15's on 15x8 rims? [Re: SandRaider] #961128 08/30/09 05:53 AM
DRaider90 Offline
Keep in mind back spacing most greatly helps with the width of tires not the diameter. I have 34x9.5s on stock bs Alloys, but if I had some 15x8s with stock bs and 34x12.5s it wouldn't work more than likely. The diameter of both tires is 34", but its the width that makes the difference.
For that matter 10.5" wide tires will fit with stock back spacing on stock rims. With the wider rims any back spacing 4" and below should be more than enough. 3.75" will more than plenty with enough room to run 12.5s later on.
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: offset on gen1 running 31x10.5x15's on 15x8 rims? [Re: DRaider90] #961129 09/01/09 06:54 AM
mike71800b Offline
Let me know how those summit wheels work out, I have been thinking of a set myself.
The raider i recently bought has 32 x 11.50's on it with what looks like 15 x 12" jc whitney fake beadlock wheels.
The outer edge of the tire is just wide enough to scrub into the plastic bumper end in the front when steered just right. Tire doesn't seem to catch anywhere else when stuffed, and no probs in the rear.
Anyone know if a 15 8 , or a 15 x 10 wheel will allow 32x11.5's without scrubbing? They're Pro Comp tires with 1/2 inch of tread or so left so I'd like to make them work if possible.
THanks!
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: offset on gen1 running 31x10.5x15's on 15x8 rims? [Re: mike71800b] #961130 09/01/09 07:42 AM
SandRaider Offline
I use 15x8 pro comp rock crawler (looks exactly like cragar soft 8) with 3.75" backspacing. I've ran 31x10.5 tires with no rubbing ever, but my current 35x12.5 tires on those same wheels rubbed when turning before I put the 3" body lift on, then only the driver side rubbed on the inner fender well when turning right, now it doesn't rub at all, even when stuffed, thanks to a big hammer on the inner fender.
Eric
Re: offset on gen1 running 31x10.5x15's on 15x8 rims? [Re: mike71800b] #961131 09/01/09 08:04 AM
DRaider90 Offline
THanks!
15x8s are the widest wheel you should run 11.5" wide tires on. Running them on 15x10"s or 15x12"s is asking to pop beads. You should be fine with the 32x11.5s mounted on 15x8s.
Re: offset on gen1 running 31x10.5x15's on 15x8 rims? [Re: powerRam50] #961132 12/14/09 10:59 PM
MI_Mitsu Offline
Good to hear - especially since the wheel FAQ shows a 15x8 needs a 3.25 backspace.
Can anyone vouce for the min and max backspace limits for a 15x7 and a 15x8 wheel?
Jim
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6422 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-06-07 06:11:21 UTC
