Got the Plenum off of my 93. It was eaiser than I thought. Been having major blow by so I figured I'd start there. PCV was bad. You could blow air both ways. I noticed the two coolant hoses that run to the IAC were getting pretty hard. I'll replace those. I'm guessing use real hose clamps instead of the ones that are OEM?. Should I do anything to the IAC while the Plenum is off? I looks easy to remove. Also what is the best way to clean the Plenum? Can you tank them?..Also thought about getting new vac hose and replacing the ones I can get to. Any thing else i need to do?? Also noticed there is no EGR on this motor..
Thanks!! <img src="/forums/images/graemlins/patriot.gif" alt="" />
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around
95 LS-- Dual Bouncy Seats 234k and still rockin'
