1995 Montero color question #961671 09/02/09 01:12 PM
Y
yankee7809 Offline OP
Does anyone with a silver '95 Monty LS have any idea what the lower cladding color is called? I've done a search everywhere and not found anything that would indicate a name. Those cladding parts are still available from Mitsubishi ( $$$) but they show a black option and a gray one as well. They appear to be dark metallic grey paint but who knows with car companies nomenclature. Thanks for any clues to the correct color!
1995 Montero LS, KYBs, Michelin 31s. 2009 Kia Borrego EX. (Wife's wheels.)
Re: 1995 Montero color question [Re: yankee7809] #961672 09/02/09 01:55 PM
Not sure what it's called but your best bet if nobody has an answer is to take your VIN into a dealership and ask them your paints color code & name. Using the code, you can go to any car paint place and they can create a match for the original color. If your paint has faded/aged however then you may need to paint more or all of the body cladding so that it matches. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1995 Montero color question [Re: off-roader] #961673 09/02/09 01:58 PM
Y
Thanks for the idea, Had thought maybe that the VIN might reveal the lower cladding color as well but wasn't quite sure.
Re: 1995 Montero color question [Re: yankee7809] #961674 09/02/09 04:11 PM
I think there are trim codes on there as well, on the underhood data plate
Re: 1995 Montero color question [Re: fasteddy] #961675 09/02/09 05:21 PM
Zactly... First number should be body and second trim...
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.011s) Memory: 0.6099 MB (Peak: 0.6748 MB) Data Comp: Off Server Time: 2026-11-17 11:19:00 UTC
