Auto Tranny - ????? No Go #961746 09/03/09 03:06 AM
trcdrunner Offline OP
My brothers - 86 22RE 4x4 Auto..
Well got around to replacing torq converter... Just got it back togther - BUT it will not move??? any ideas?
- All linkage are hooked up and looks to be moving and operational.
-Throttle cable hooked up
-Plug & wires all connected
- Tcase in any gear Tranny in any gear will not move
When in park and rocked by hand - seems to BE in park will not roll fwd or back..
Any other gear truck can be rocked as if in neutral...
When running truck just revs as if neutral...
When put togther - TQ Convert was placed on tranny, then bolted to flywheel thru that PIA opening...
Any thoughts - did I miss something - I hope I dont have to pull this all apart again...
TIA -
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: Auto Tranny - ????? No Go [Re: trcdrunner] #961747 09/04/09 12:45 AM
Staceman Offline
You didn't mention that you put in fluid. Did you?
Re: Auto Tranny - ????? No Go [Re: Staceman] #961748 09/04/09 01:57 AM
CJMT100 Offline
Did you make sure the TC was fully clicked in? Sometimes they gotta be rotated and fit in all the way-if not the situation you have can occur.
Re: Auto Tranny - ????? No Go [Re: Staceman] #961749 09/04/09 03:52 AM
Poured some directly into TC then aligned the TC on the splines of the tranny...Slide upto motor.. then mounted the TC to the flywheel via that opening.. Then put bout 4qts fluid in thru the dipstick - then fired up...
Fully 'clicked in'?? onto the output splines of tranny, it was all the way on tranny didnt push to click??? did seem that when bolting TC to flywheel it seemed like it was being pulled away from tranny (you follow)(slightly)
aka FireNIce
TRCD Toys Web Site
TRCD Toys Apperal
Re: Auto Tranny - ????? No Go [Re: trcdrunner] #961750 09/06/09 05:22 PM
RockCrawl86 Offline
Hey, this is the owner of the 86 with the tranny probs (trcd's brother) I was lookin around and saw a couple small wires that seem to originate out of the trasmission right about where the TC is. - Not too sure where they go...
I understand the older trucks have will have loose wires with no homes, but hey - worth a shot.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6057 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-07-14 12:15:19 UTC
