1st Gen Monty Disc Brakes #961890 09/03/09 06:38 PM
HalfbreedinKC Offline OP
I'm curious, was any generation of the Montero ever equipped with 4-wheel disc brakes? If so which one(s)?
HBinKC
Re: 1st Gen Monty Disc Brakes [Re: HalfbreedinKC] #961891 09/03/09 06:56 PM
mrr Offline
My Gen II has 4 wheel disk brakes
1995 SR
Re: 1st Gen Monty Disc Brakes [Re: mrr] #961892 09/03/09 07:37 PM
zarktheshark Offline
TMK, no gen1 had rear disks but there are swap options for both leaf sprung and coil sprung gen1's.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: 1st Gen Monty Disc Brakes [Re: zarktheshark] #961893 09/03/09 07:57 PM
0778drz110 Offline
some overseas Gen1s had discs...
gen2 have rear discs
swap in a gen2 rear with 4.636 gears if you want discs
Re: 1st Gen Monty Disc Brakes [Re: 0778drz110] #961894 09/03/09 08:00 PM
This is the info I was wanting - thanks guys!
Re: 1st Gen Monty Disc Brakes [Re: HalfbreedinKC] #961895 09/03/09 10:37 PM
sparkem Offline
My gen1 has rear discs. It also has a 95SR rear axle.
I always wanted to try to put discs from a Montero Sport on the gen1 9in.
Re: 1st Gen Monty Disc Brakes [Re: sparkem] #961896 09/04/09 02:59 AM
Jamez Offline
Is there a write-up for the V6 brake swap? The swap plus a Sport axle sounds like a good all-around upgrade for us 4 pots.
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: 1st Gen Monty Disc Brakes [Re: Jamez] #961897 09/04/09 04:17 AM
Pete_D Offline
I put the 95 SR in my SWB 90 - it's a great add for what was originally an under braked vehicle. Well worth the effort to get the result. Stops better than my 05 4 Runner and my SC 400 under non abs conditions.
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: 1st Gen Monty Disc Brakes [Re: Pete_D] #961898 09/04/09 04:51 AM
I did the montero sport rear swap on my gen1 and love it. if the rig has leaf springs, read land raiders write up. http://www.4x4wire.com/forums/showf...;amp;page=0&fpart=1&vc=1
'15 Subaru XV
'03 BMW i325
Re: 1st Gen Monty Disc Brakes [Re: zarktheshark] #961899 09/04/09 07:39 AM
4ePajero Offline
My 1989 Gen1 (Japan Import) has disk brakes all-round (on 4.875 axles).
I have subsequently changed to front to Gen2 twin-pot callipers, which is a straight bolt-on process except for
* trimming the dust shield.
* bending the brake pipe a touch.
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.004s) Memory: 0.6372 MB (Peak: 0.7601 MB) Data Comp: Off Server Time: 2026-06-07 04:35:39 UTC
