Rating: 2
Page 2 of 4 1 2 3 4
Re: 4G54 & 6G72 motor info. [Re: 0778drz110] #961979 09/05/09 02:48 AM
Montero_Jim Offline
Check the transmission shift detent cable before assuming the transmission is bad. I've seen 3 Gen I automatics recently with the trans cable jacket pulled out of the crimp. Slide the rubber sleeve back near where the cable ties into the throttle body linkage. When it slips out, the transmission will shift erratically, with typically very late, neck snapping upshifts. It's not fun to change it(drop the pan and remove the valve body), but a replacement is only about $50.
1987 Raider
1991 Montero LS
Nipomo, CA
Re: 4G54 & 6G72 motor info. [Re: mecha_sky] #961980 09/05/09 04:21 AM
Va_Stumpy Offline
Can't say that I know much about the 4 cyl. I bought an '89-V6 from my father-in-law for $75 last year. It had 229,000 miles on it. The only thing that doesn't work is the rear window defroster. I put about 3000 miles on it & the oil pressure started to fade. I dropped in a new long block & drive it every chance I get.The V6 has power to spare, it has never let me down. I've gotten out of every tight spot I've ever been in w/ it.(That's more than I can say for my '95 Silverodo Z71)I wish I could find another 1 just like it.Good luck w/ your research.... I believe what ever you chose you will like the outcome.
Greg
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: 4G54 & 6G72 motor info. [Re: 0778drz110] #961981 09/05/09 04:54 AM
Grasscat Offline
Even in the mountains I still don't have to wind out the motor up steep hills, I call do almost all at 3k rpm.
Mountains and steep hills in Florida? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: 4G54 & 6G72 motor info. [Re: Grasscat] #961982 09/05/09 05:08 AM
Rayman Offline
I own 3 rigs with the 4g54 motor and one with the 6G72
24 valve. The 6G72 gets better mileage and has more power
than the NA 2.6L. Turbos I know nothing about. I like
my diesel 4D55 best for the torque and gas mileage.
Ray
In the Pacific Wonderland
95 Montero 5 spd
87 Raider 2.6 5 spd
65 MG Midget
2002 Integra GSR (wife's car)
Re: 4G54 & 6G72 motor info. [Re: Rayman] #961983 09/05/09 07:50 AM
Kevin C Offline
We need to get the PNW / PDX group together.... Seems like there are quite a few of us.
I can host. When is a good time?
Kevin
Re: 4G54 & 6G72 motor info. [Re: mecha_sky] #961984 09/05/09 11:56 AM
HalfbreedinKC Offline
Do any of you know how much the Montero 4door weighs?? Just curious
Everything you wanted to know about the Montero but were afraid to ask...
http://en.wikipedia.org/wiki/Mitsubishi_Pajero
http://www.cars.com/go/crp/research.jsp?...mp;aff=national
Re: 4G54 & 6G72 motor info. [Re: HalfbreedinKC] #961985 09/05/09 12:06 PM
And the second link, a review, lists the curb weight at 3,979 lbs.
Re: 4G54 & 6G72 motor info. [Re: HalfbreedinKC] #961986 09/05/09 02:14 PM
Mine has 2.6 auto and works great. The thing had the overdrive relay out, and I don't know how long he drove it around without OD, but the engine is still great. The only problem is the #3 cylinder burns a bit of oil. I'm on the hunt for another 2.6 to rebuild while I drive on this on.
Re: 4G54 & 6G72 motor info. [Re: fasteddy] #961987 09/05/09 02:17 PM
fasteddy, what is the easy turbo conversion?
Re: 4G54 & 6G72 motor info. [Re: Grasscat] #961988 09/05/09 05:53 PM
0778drz110 Offline
Someone always asks that.. damnit <img src="/forums/images/graemlins/cyclops.gif" alt="" /> I live in Fl I use my raider in NC.
The manual definitely helps! <img src="/forums/images/graemlins/scared.gif" alt="" /> I don't think you could drive steep roads with a automatic 2.6l with those weenie brakes! I've had my close calls <img src="/forums/images/graemlins/smile.gif" alt="" /> 4-wheel brake skids around switchback in fun! <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" /> Guess thats why ABS was invented <img src="/forums/images/graemlins/smile.gif" alt="" />
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6448 MB (Peak: 0.7703 MB) Data Comp: Off Server Time: 2026-05-30 01:19:00 UTC
