Transmission Key Crushed #962487 09/09/09 03:22 AM
blinkerbox Offline OP
In my haste I crushed the key on the engine side of my V4AW2. I fitted the torque converter on but apparently failed to engage it all the way onto the transmission, needing the last 10mm or so. Thinking I had it all the way on I attempted to mate the engine to the transmission and in the process crushed both sides of the key. I plan on heading to the junkyard, possibly this weekend to take the front plate off a transmission to see if I can salvage that part. Has anyone been into this part of the transmission?
'91 RS, '93 SR
Re: Transmission Key Crushed [Re: blinkerbox] #962488 09/09/09 04:37 AM
I think you are talking about the oil pump....
Re: Transmission Key Crushed [Re: fasteddy] #962489 09/09/09 04:56 AM
justice Offline
Ouch..Sorry man..I almost made the same mistake a few weeks back. I decided not to force it and dropped it back down and finally got the TC fully engaged after spinning and pushing for about 15 minutes.
Re: Transmission Key Crushed [Re: justice] #962490 09/09/09 05:01 AM
Has anyone pulled the cover off the front of the transmission to get to the inner workings? I really don't like to touch transmissions, however if there isn't anything to difficult to manage to get to this component, I'd be up for it.
'91 RS, '93 SR
Re: Transmission Key Crushed [Re: blinkerbox] #962491 09/09/09 05:17 AM
StockRaider Offline
umm... good luck bro. <img src="/forums/images/graemlins/scared.gif" alt="" /> For future reference you have to push the torque converter on my rotating it in 3 steps. full turn clockwise, full turn counter clockwise, and usually half a turn clockwise. Brendan screwed up the first transmission he had in the blue montero. I have had to do trans work about 3-4 times now, and never had a problem following those steps. takes 30 seconds to be sure <img src="/forums/images/graemlins/kewl.gif" alt="" />
You will have to be sure the pump is the right one or it will not work. I think the length between lockup and non lockup converters are too differnt to be cross compatible.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Transmission Key Crushed [Re: StockRaider] #962492 09/09/09 05:21 AM
Yeah it's the pump.
'91 RS, '93 SR
Re: Transmission Key Crushed [Re: blinkerbox] #962493 09/09/09 05:29 AM
Thanks StockRaider. Yeah, I feel kinda stupid considering I pulled the engine out a couple of times on my last Montero. I suppose the brain cells stopped working at about 3am.
'91 RS, '93 SR
Re: Transmission Key Crushed [Re: blinkerbox] #962494 09/09/09 05:37 AM
StockRaider Offline
did you mess up the pump? or the squash the converter? no consolation either way, but if its the converter its a little easier at least than tearing into your trans. You could always just find a lower miles junkyard trans and swap the whole unit. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Ive got trans swaps down to a personal record of 5 hours out 4 hours in. <img src="/forums/images/graemlins/kewl.gif" alt="" /> (faster if I didn't use a torque wrench)
(extra hour out is for PBblaster and beer/soda) <img src="/forums/images/graemlins/cheers.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Transmission Key Crushed [Re: StockRaider] #962495 09/09/09 06:03 AM
I crushed the key in the pump. I believe this also made the shaft on the torque converter misshape. Couldn't I just replace the pump and tc?
'91 RS, '93 SR
Re: Transmission Key Crushed [Re: blinkerbox] #962496 09/09/09 06:50 AM
87Montero Offline
I was the one that killed a trans the same way.. but in my case, I was up till 3 am the night before killing brain cells and the next day having taking breaks on the tranny install to puke outside the garage. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> Yes, I've grown up a little since then <img src="/forums/images/graemlins/wink.gif" alt="" /> Definetly a kick in the balls to hear that sound when firing it up after a painfull weekend.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6434 MB (Peak: 0.7675 MB) Data Comp: Off Server Time: 2026-05-29 18:59:20 UTC
