Page 3 of 3 1 2 3
Re: carburetor/motor help! [Re: yotaman1224] #962668 09/12/09 05:19 PM
4x4Wire Offline
One thing you may want to try is disconnecting the fuel line at a convenient spot and blow air back into the tank.
With a 76 model, there could be some interior tank rust or other crud that is partially plugging the fuel pick-up tube in the tank.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: carburetor/motor help! [Re: 4x4Wire] #962669 09/13/09 02:02 AM
Y
yotaman1224 Offline OP
^^^thats exactly what i did today and it still wouldnt run so i hooked up a fuel cell in the back and now its workin so im guessin the fuel tank sucked up some [censored] thanks for all the help guys!!!!
Re: Just for kicks and grins [Re: yotaman1224] #962670 09/13/09 03:41 AM
BigJim Offline
If you have enough fuel in your tank? It sounds like a split in your rubber hose is causing air to be sucked in the line. Common problem with the hose on the top of the tank.
Big Jim
Re: Just for kicks and grins [Re: BigJim] #962671 09/13/09 05:55 AM
Y
could be it had 8 gallons in there had enough gas lol but all i did was take off the rubber hose from the hard line back by the gas tank and put on my own and put it in a boat gas tank and it worked so either the pickup on the tank was clogged or it had a split in the line?
Re: Just for kicks and grins [Re: yotaman1224] #962672 09/13/09 10:45 AM
4x4Wire Offline
I would opt for a clog in the line.
A split in the line would have spilled fuel.
Working on that issue now with my YJ... Replacing rotten fuel lines.
John Stewart
Editor - 4x4Voice
Re: Just for kicks and grins [Re: 4x4Wire] #962673 09/14/09 12:05 AM
sunder Offline
I've had split in old rubber lines that didn't leak but did suck air when the pump was running full bore. Apparently their is a higher vacuum on the lines from the pump, than pressure in the lines from the hydrostatic head in the tank. No gas leaks, but the lines suck air...
91 YJ
2 Seater Sand Rail
Handfull of other fun toys...
And a brand new, spit shined, B.S.
Oh, and a job to boot.
Re: Just for kicks and grins [Re: sunder] #962674 09/14/09 02:00 AM
Y
it was a clogged pickup in the tank too old of a tank and ran it dry too many times lol
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6266 MB (Peak: 0.7166 MB) Data Comp: Off Server Time: 2026-10-22 02:14:52 UTC
