oil filter is dry #962675 09/10/09 01:34 PM
4x4runner Offline OP
I changed the oil in my '85 22re yesterday, and noticed the oil filter was as clean as the day I installed it. The oil from the crankcase was black and the inside of the filter was almost dry and clean. Is there a ball check valve or something not allowing oil into the filter?
Re: oil filter is dry [Re: 4x4runner] #962676 09/10/09 05:14 PM
DRTDEVL Offline
Bad relief valve?
Re: oil filter is dry [Re: DRTDEVL] #962677 09/10/09 11:00 PM
Is the relief valve located in the engine block behind the housing where the filter screws on? I checked my FSM, and did a search here and Pirate. I couldn't find anything about the dry filter or a relief valve. I have good oil pressure but I am concerned about the filter not getting any oil run through it.
Re: oil filter is dry [Re: 4x4runner] #962678 09/11/09 02:17 AM
kewlynx Offline
The relief valve is part of the oil pump on the front of the block, pax side on top. You'll see a hex plug there; that's where the relief valve lives.
If it's a Toyota filter, it also has a drain back, so you might think it's dry; does it smell like oil?
Also, if going by the stock gauge for oil pressure, remove one of the little 8mm plugs near your oil filter, install a pressure gauge, and see what you get for a pressure reading.
**ubi apis- ibi salus**
Re: oil filter is dry [Re: kewlynx] #962679 09/11/09 12:25 PM
OK I remember seeing that plug when I installed the oil pump a few years ago. I don't know what to look for after I take the plug out. Anyone have a break down of whats inside?
Re: oil filter is dry [Re: 4x4runner] #962680 09/11/09 02:46 PM
OOP'S Offline
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: oil filter is dry [Re: OOP'S] #962681 09/14/09 07:33 PM
Stevie Offline
Don't good-quality oil filters have check valves in them so as to allow some oil to stay within and not drain out between starts? All in an effort to avoid dry startups?
'80 4X4 Longbed
Re: oil filter is dry [Re: Stevie] #962682 09/15/09 12:58 AM
Ralph Offline
K&N filters do.
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: oil filter is dry [Re: Ralph] #962683 09/19/09 09:14 PM
yodta Offline
what's the latest on this peculiar problem?
msg - '87 xtracab
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6295 MB (Peak: 0.7161 MB) Data Comp: Off Server Time: 2026-05-25 19:03:05 UTC
