10 bolt input bearings #963498 09/15/09 05:58 AM
JKrawler Offline OP
A few years ago I was looking for replacement input bearings for rear 10 bolt diffs. At that time there weren't any that anyone could point me to.
Now between my dad and I we have 3 rear and 1 front that are toast.
Has a solution been found yet, has anyone discovered another bearing that works but isn't listed for this application?
Buying whole third members for such a small problem seems to be counter productive to me and I would like to be able to pass on a couple extras.
93 Isuzu Trooper S w/ 3" Suspension Lift & 32" rubber.
94 Toyota Hilux Surf 3.0 TD,... more to come
Re: 10 bolt input bearings [Re: JKrawler] #963499 09/16/09 12:43 AM
mlclark Offline
Isuzu Moderator
Take the bearing to your local bearing/seal supply house. They will be able to find you one that will work.
Good luck,
Michael
Re: 10 bolt input bearings [Re: mlclark] #963500 09/23/09 01:20 AM
JKrawler Offline OP
Thanks, that sounds like it will be quite a bit cheaper than buying another diff. Now to find one of those near the truck... And get the old Bearing out...
Re: 10 bolt input bearings [Re: JKrawler] #963501 09/23/09 03:48 AM
mlclark Offline
Isuzu Moderator
Try THIS link.
It has bearing part numbers for you. You should be able to source all the bearings for the 10-bolt pretty easy.
Now, I would not take these part numbers for gospel. Isuzu is pretty darn good at using the same parts across years, but you never know. But, it gives you a place to start.
You might even be able to cross reference and order them from an online supplier.
Good Luck,
Michael
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6045 MB (Peak: 0.6605 MB) Data Comp: Off Server Time: 2026-06-17 04:21:37 UTC
