Gen 1 Radio interface question #963542 09/15/09 05:39 PM
RocLimer Offline OP
Has anyone seen a cable that fits the 7-pin DIN plug on the back of a single din radio? I think its there for a secondary input as the single din player doesn't have a tape player integrated to it. The plug looks something like this:
I haven't yet cracked the case open, but would like to crack a ipod adapter to have a remote in from an ipod and be able to charge it to as i suspect there is a grounding and powered wire integrated for the auxiliary tape deck. I have looked at the electrical diagrams and from what I can see there aren't any specifics of what each pin does. Any help would be useful.
1989 Montero 2-Dr 3.0L V6 15X8 ProComp 97 Series w 30.5x9.5 Cooper M/T's
http://www.cardomain.com/ride/3143932
Re: Gen 1 Radio interface question [Re: RocLimer] #963543 09/15/09 09:53 PM
Y
yankneck696 Offline
That must be the antenna tuner interface plug...LOL
I think it'd be pretty easy to figger out if you open it up.
The ground is simple, then you need the audio amp input. You might also find it's not possible, because the head unit needs to sense the tape player....
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: Gen 1 Radio interface question [Re: yankneck696] #963544 09/16/09 12:12 AM
RocLimer Offline OP
The 1989 and 1987 electrical audio diagrams show a 7-wire cable going between the radio tuner and the tape deck when offered separately. The head unit would most likely pickup the presence of a ipod as there would most likely be a signal wire which would signal the radio to switch from radio to tape mode when a tape is inserted.
Ipod pinouts
Re: Gen 1 Radio interface question [Re: RocLimer] #963545 09/17/09 12:14 AM
RocLimer Offline OP
This is what I'm talking about:
Back of stereo
Close-up of 7-pin DIN plug
Close-up of back of plug
6-wire cable leading to printed board
Thoughts?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6014 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-06-23 13:07:43 UTC
