Page 1 of 3 1 2 3
Need help with diagnoses on my 3.0L #963873 09/18/09 02:40 AM
shorepig Offline OP
So....
My 3.0L V6 with about 130 000 miles is giving me problems. It began with a blown coolant hose....one that goes to the heater core. I replaced this hose, and now the motor has overheated once, and I even heard some detonation (pinging). I shut it down and had it towed home. The next time I started the truck up it idled very high?
I replaced the thermostat, because it was easy, inexpensive, and I've never changed one before, and wanted to give it a try. The truck is still overheating.
Here are the the facts:
1) when I squeeze the upper rad hose (where coolant flows into the rad) it is very very firm, and hot. So firm, that I can barely squeeze it. My repair manual says I should be able to squeeze it, let go, and hear coolant refilling it. I don't hear this happening. The manual says this is a sign of a bad water pump.
2) After about 4 minutes of running, the temp climbs very quickly, and it climbs into the hot zone, so I shut it down.
3) I checked the rad, and there seems to be no coolant in it. I topped it up with about a litre of coolant. This did not seem to help.
4) About 6 months ago, the heater fan stopped working. It was intermittent at first, then eventually stopped altogether. I haven't fixed this.
5) I have grabbed onto the water pump shaft (the one that is in the center of the fan) and attempted to wiggle it up and down to check for play. NO PLAY. The manual says if there is play than that could be a faulty water pump shaft.
6) Since I've owned the vehicle (2 years, about 30 000 miles) I have noticed that it goes through alot of coolant...about 1 litre every few thousand miles) There were never any signs of leaking.
7) My oil is not milky, so I'm hoping it is not head gasket related
So I'm thinking it is a clogged radiator or the water pump. ARE THERE ANY OTHER CHECKS OR TESTS I CAN DO TO NARROW IT DOWN FURTHER? Can I put a hose on the top of the rad, and open the drain on the bottom of the rad and see if there is flow from top to bottom?
Any help would be great!
92 Mighty Max V6 4x4 SWB
32's, torsion lift, yota lift shackles in the back, rear LSD, 4.22's
safari rack, 3" body lift
85 VW Westfalia Baja beast
1975 HONDA CB500T cafe racer
Sector 9 pintail
Re: Need help with diagnoses on my 3.0L [Re: shorepig] #963874 09/18/09 03:06 AM
FrankR Offline
It sounds like a blown head gasket to me.
You can test the radiator somewhat by removing the cap and opening the lower drain valve. IIRC, a healthy radiator should completely drain in about 1 minute.
Frank
Re: Need help with diagnoses on my 3.0L [Re: FrankR] #963875 09/18/09 03:18 AM
Va_Stumpy Offline
I hate to tel you Bud ;but on the 3.0 the fan is attached to an idler.. not the water pump. You may have a bad radiator cap or a small hole in the cooling loop. The fluid will evaporate when the engine is up to operating temp. The easiest way to check is to use a cooling system pump. Remove the radiator cap when the engine is cold,pump it up to the normal operating pressure & look for the leak. There are 2 freeze plugs on the back of the engine covered by the bell housing. I found 1 on my engine that looked really nasty when I pulled it out for an engine swap.Usually coolant going into the combustion chamber results in steam from the exhaust all the time...you know, like when you make a short trip in the dead of winter. Good luck & let me know how this problem turns out. I hope this has been helpful.Low coolant doesn't always = blown head gasket.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Need help with diagnoses on my 3.0L [Re: Va_Stumpy] #963876 09/18/09 03:45 AM
but it will very soon.
Three tests at minimal expense. Compression test. Radiator pressure test (rent the tool at the auto parts store).
Dye test for exhaust products in the coolant. Lisle Tools kit to check for it for about $50. Buy at a good auto parts.
I've got $5 that says the radiator core is at least partially clogged, too. Time to rod it out or recore.
Re: Need help with diagnoses on my 3.0L [Re: fasteddy] #963877 09/18/09 04:06 AM
Va_Stumpy Offline
Fast Eddy has some sound advice & he may be right. I bought a raider from my father-in-law that had been setting under a pecan tree for 6 yrs. I had some issues w/ it & did some basic troubleshooting that didn't cost a lot of money & found there were simple answers to MY problems. Just don't go running around waving your hands in the air screaming "The sky is falling !!!" when you really aren't sure yet. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Va_Stumpy
89 Raider
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Need help with diagnoses on my 3.0L [Re: Va_Stumpy] #963878 09/18/09 04:13 AM
MBrannon Offline
As said, compression test and coolant system pressure test should do it.
My money is on the head gaskets.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Need help with diagnoses on my 3.0L [Re: MBrannon] #963879 09/18/09 04:47 AM
Va_Stumpy Offline
I've owned several vehicles with well over 200,000 miles on them & have never had a head gasket problem with any of them.... Maybe we have better water in VA? Who knows ?
Va_Stumpy
89 Raider
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Need help with diagnoses on my 3.0L [Re: Va_Stumpy] #963880 09/18/09 04:53 AM
MBrannon Offline
I've only seen one rare type of head gasket failure in a 6g72 with MLS headgaskets, but these composite ones suck!
1998 Montero
2007 Prius
Re: Need help with diagnoses on my 3.0L [Re: MBrannon] #963881 09/18/09 06:51 AM
Oyaji_Jon Offline
MLS?
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Need help with diagnoses on my 3.0L [Re: Oyaji_Jon] #963882 09/18/09 11:23 AM
FrankR Offline
MLS = multi-layer steel..... which require a very fine machine surface on the heads and block to avoid leaking..... they're not for everyone unless you have a machine shop with much better than average results.
The reason I said the head gaskets may be blown is because the upper radiator hose is very tight and a heater hose ruptured - perhaps from steam, but also likely from combustion gas pressure. If the head gaskets haven't failed, they soon will as Eddy said.
What could cause the head gasket(s) to fail? Likely a clogged radiator - also as Eddy said.
All speculation until the diagnostic and forensic work is done.
3.0L engines blow head gaskets if the cooling sustem isn't kept in good condition - radiators and cooling fan clutches are the main culprits.
Composite factory gaskets are fine..... and preferred by me...... even with moderate amounts of forced induction.
Frank
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.012s) Memory: 0.6454 MB (Peak: 0.7718 MB) Data Comp: Off Server Time: 2026-11-04 20:01:17 UTC
