Slipping clutch for months now...what else will be damaged? #963970 09/19/09 05:37 PM
shorepig Offline OP
I've had a slipping clutch in my Mighty Max V6 3.0L for the past 5 months, and I've put on about 4000 miles. The strange thing is, it is easy enough to drive while preventing it from slipping. As long as I am gentle, no slippage. I haven't been able to afford the repair, and I'm concerned that driving the truck as is may damage something else. The mechanic at the transmission shop said it will not damage any thing else, but I need reassurance from the real experts! <img src="/forums/images/graemlins/smile.gif" alt="" />
92 Mighty Max V6 4x4 SWB
32's, torsion lift, yota lift shackles in the back, rear LSD, 4.22's
safari rack, 3" body lift
85 VW Westfalia Baja beast
1975 HONDA CB500T cafe racer
Sector 9 pintail
Re: Slipping clutch for months now...what else will be damaged? [Re: shorepig] #963971 09/19/09 06:10 PM
LRJ4x4 Offline
Clutches are optional is you can shift correctly. <img src="/forums/images/graemlins/cheers.gif" alt="" />
At some point it will leave you stranded when It completely goes and won't go into gear. Just keep your tow card handy.
You should get it fixed, there is always a possibility it will fall apart and sling bits and pieces everywhere.
Re: Slipping clutch for months now...what else will be damaged? [Re: shorepig] #963972 09/19/09 09:47 PM
mike71800b Offline
Well expect to resurface the flywheel, all that extra heat can cause hard spots that make the engagement feel jerky if y ou just throw it back together. Also warpage that only allows good disc clamping in the high spots. That extra heat is also hard on the rear main seal. And you should definatly replace the pressure plate, pilot bearing, and throwout bearing. Trans input seal is only a few bucks and you'll be right there anyhow.
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: Slipping clutch for months now...what else will be damaged? [Re: mike71800b] #963973 09/20/09 12:03 AM
V
vr4 Offline
only thing that could be damaged beyond repair is the FW
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.014s) Memory: 0.6044 MB (Peak: 0.6605 MB) Data Comp: Off Server Time: 2026-11-04 20:00:40 UTC
