Still having problems with engine pressure in my 93..HELP! #964088 09/20/09 05:19 PM
brubren3815 Offline OP
Well took everybody's advice and changed out the PCV, (That was fun) Also changed out the coolant hoses that go into the idle motor. Mew wires,cap,and rotor.It still runs like crap at idle and blows smoke back up through the engine. If I leave the oiler filler cap on it builds up a pretty good amount of pressure until I release it. I am stumped! Could the cat be plugged? What else could be causing so much back pressure??? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around
95 LS-- Dual Bouncy Seats 234k and still rockin'
Re: Still having problems with engine pressure in my 93..HELP! [Re: brubren3815] #964089 09/20/09 08:06 PM
4ePikanini Offline
sounds like ring blow by.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: Still having problems with engine pressure in my 93..HELP! [Re: brubren3815] #964090 09/20/09 08:19 PM
FrankR Offline
Rings, a holed piston or a blown head gasket - you're pressurizing the sump.
Frank
Re: Still having problems with engine pressure in my 93..HELP! [Re: FrankR] #964091 09/20/09 08:41 PM
mike71800b Offline
You can test for a clogged cat with a vacuum gauge on the intake manifold. It will start up with a decent ammt of hg and then vac gauge will drop down. Or unbolt the cat on the manifold side and go for a loud ride. Now doing a compression test is the easiest way to check for bad rings, valve seats, or a hole if you are that unfortunate. Bottom line is you can test all this yourself with < $50 of gauges.
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6039 MB (Peak: 0.6596 MB) Data Comp: Off Server Time: 2026-06-10 01:43:14 UTC
