Transmission Info for 93 #964327 09/21/09 09:40 PM
blinkerbox Offline OP
I'm going to be heading out to the junkyards over the next couple of weeks to find a replacement transmission. I've got a '93 SR auto (V4AW2). My question is, what years did Mitsubishi put this trans on?
'91 RS, '93 SR
Re: Transmission Info for 93 [Re: blinkerbox] #964328 09/21/09 10:38 PM
Bagpiper Offline
Are you going to rebuild it? I saw the motor you rebuilt totally awsome. that tranny is one for the 3.0 types isn't it,there are a lot of them here in town so I'll check on it and see what they have.
Re: Transmission Info for 93 [Re: Bagpiper] #964329 09/21/09 10:43 PM
No, I want one that works. Yeah, it's 3-liter. If I found one that was out of the vehicle that would make me a happy camper. Also looking for a torque converter.
'91 RS, '93 SR
Re: Transmission Info for 93 [Re: blinkerbox] #964330 09/21/09 10:48 PM
Bagpiper Offline
ok, a working tranny and your in Colo, too! so not much of a problem. I'll go after work tomorrow! <img src="/forums/images/graemlins/kewl.gif" alt="" />
95 Montero SR/NANKANA 31 10.50 AT/Bouncy seat/Cobra CB/K&N air cleaner/Hi-lift Jack/Jerry Can/ tweaked torsion bars/Timing belt assembly/ Rage roof rack/ triple gauge system /Superwench hubs/2.5" lift/
92 Nissan Pathfinder XE (the Wife's)
Re: Transmission Info for 93 [Re: Bagpiper] #964331 09/22/09 03:48 PM
So back to my original question, what years had the V4AW2?
'91 RS, '93 SR
Re: Transmission Info for 93 [Re: blinkerbox] #964332 09/22/09 05:27 PM
justice Offline
91-93 (and possibly some 90's)
Keep in mind if the gen 1 and 2 use a different tailhousings on the same trans to mate to the standard vs activetrac T-cases.
Re: Transmission Info for 93 [Re: justice] #964333 09/22/09 05:31 PM
Yeah, not really looking into pulling a trans without a tailhousing so that won't be an issue. I guess that narrows it down to 92-93 for a replacement for my 93.
'91 RS, '93 SR
Re: Transmission Info for 93 [Re: blinkerbox] #964334 09/22/09 06:28 PM
I've found a yard with a base model '93. Did Mitsu do anything different with the trans or torque converter between the trim lines that year?
'91 RS, '93 SR
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6217 MB (Peak: 0.7004 MB) Data Comp: Off Server Time: 2026-05-29 18:58:37 UTC
